Center console removal 09-11 - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Old 06-10-2012, 06:48 PM
ImAHemi ImAHemi is offline
Vehicle: 09 Ram QC
Color: Deep water blue pearl
Rep:24
ImAHemi is on a distinguished road
Thank, you! yes it just popped right off!
Old 06-11-2012, 09:31 PM
moparornocar72's Avatar
Rep:630
anytime man! glad it worked out!
14.268 @ 95 MPH Full Trim
Old 06-13-2012, 01:56 AM
BradZ's Avatar
BradZ BradZ is offline
Vehicle: 2011 Dodge Ram QC
Rep:23
BradZ is on a distinguished road
got any pix of what it looks like overall with the big center console out? I'm thinking of trying to get rid of the thing for more legroom/sub room. Not sure if I could still keep the shifter or possibly move it somehow though but be nice to see how much room was in there.
Old 06-13-2012, 05:06 PM
Rep:630
I sure don't hopefully some1 that has done a stereo install will have pics for you!
Old 06-18-2012, 06:25 PM
Vehicle: 09 Ram QC
Rep:24
Here is a few pics from different directions of what the interior looks like without the center console.
Old 07-19-2013, 07:39 AM
RT10's Avatar
RT10 RT10 is offline
Vehicle: 2010 Dodge Ram R/T
Trim Level: R/T
RT10 is on a distinguished road
I love my R/T but I wish it had a bench seat!
Hellwig Sway Bars F&R, Magnaflow Muffler, Diablosport Tuner, Debadged, Spray In Bedliner
Old 07-03-2014, 07:19 PM
topsub topsub is offline
Vehicle: 2012 Dodge Ram Laramie
Color: Blue
Rep:156
topsub has a spectacular aura abouttopsub has a spectacular aura about
Originally Posted by ImAHemi View Post
I am removing the center console in my Ram to deaden, and removing the linkage at the shifter is holding me up. Does the rear of the linkage just pop off anyone know?
Thanks
Aron
I'm having trouble removing this as well, do I just pull to pop it off? I don't see any clips unless I'm blind?
Any help?
2016 F250 Lariet FX4 CrewCab 6.7L
2012 Dodge Laramie 4x4 CrewCab Supercharged and Lifted - SOLD
My Build Progress
Old 10-16-2014, 04:59 PM
Thebu383 Thebu383 is offline
Vehicle: 2010 Dodge ram Laramie crew
Color: Blue
Thebu383 is on a distinguished road
Default Orc
Along the same lines of this, does anybody know where the orc is located (I believe center console) and if so how to remove and replace. Truck is a 2010 ram crew cab. Thanks.
Old 07-05-2016, 12:51 AM
lhpeterson lhpeterson is offline
Vehicle: 2010 dodge ram 1500 laramie
Trim Level: laramie crew cab
Color: Black crystal
lhpeterson is on a distinguished road
i need to replace my evaporator, with the center console can i get away with only removing the front piece next to the dash
Old 07-05-2016, 02:29 AM
Rep:2929
The lid of the full floor console has to at least slide back to unscrew & remove the center console on the dash
to remove or slide back the top of the floor console
You have to lift out the rubber pads, a couple of them have screws under them
Then set your E Brake
Reach under the T handle of the shifter, the chrome collar has to slide down to allow the handle itself to lift off., i had to use a very small straight slot screw driver to loosen the collar & then i could push it down & the handle lifted right off
At this time you can lift the big rectangular chrome piece that blinds you every now & then
Now look down at the shifter itself, right next to the where the shifter would be in the Drive position, you will notice a very small rectangular tab, lift that Tab up using something like a pocket knife, the whole Tab lifts out.
Then take something about the size of a screwdriver shank & press lightly down on the RED spring loaded release that is down inside that hole & at the same time, pull the shifter to the Neutral position, you could have also started the vehicle & moved the lever, but the first way is the correct way.
This part you can do at anytime, remove the plastic panel that is down by the gas pedal, right close to where your ankle would be while you are driving, it just snaps in, no screws, then remove the same thing from the passenger side.
Now open the lower lid to the arm rest
Then grab the 2 back corners of the console lid & give a jerk up on them
You can now remove the whole upper part of the console.
There will be 2 wires to look for, 1 is a small light that illuminates the shift cover
The other connects to the cigarette lighter receptacle
That lid sort of looks like this
For the dash console
you will find 2 screws under the rubber pad at the very top of that console
Then you will find 1 more if you have a 115vac outlet, you have to remove the outer cover of the outlet to get to it, you will see a small slot just below the outlet, use a slotted screw driver or something like it & it will pop off,
There should not be any thing else holding the dash console in place besides plastic clips
I used a plastic trim tool to work my way around the cover working the clips loose
