Old 10-12-2010, 05:04 AM
dksram's Avatar
dksram dksram is offline
Vehicle: 2007 Dodge Ram 1500 Quad Cab
Rep:27
dksram is on a distinguished road
Default 20" Factory tires Not the same as SPECS. ???
I am about to buy tires for my 07 Dodge Ram 1500 with the 20" wheels.
The tires that came on it from factory are Goodyear LS2's 275/55/20
Now on the Door Sticker and at most tire stores both tell me it is suppose to be
275/60/20 WHY?
Will the 55 make the speed increase or decrease? Will putting the 60 create an issue as well?
Old 10-12-2010, 05:24 AM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
Going from a 275/55-20 (31.9") to a 275/60-20 (33.0")when your speedo reads 60 mph you are actually going 62 mph.
Old 10-12-2010, 08:59 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
Cool 55's to 60's
I had 55's till last month when i decided to switch over the 60's. the only difference other than the slight height increase and width decrease with the 60's is that my 55's would grip better tighter turns at higher speeds and less body roll than my 60's would. I would have to slow down more cuz Ill be hearing the tires starting to drift and with that extra slight body roll I was certain I was gonna flip her. Its really up to you and your preference and what the RAM's gonna be used for.Ow well ill probably be getting the 285's after I wear these out to comp for width... not really sure if that'll work or not but thats my opinion.
General Discussion is not a place to ask technical questions. Please ask specific questions in the Help Zone! Thank you for your cooperation! We are trying to clean the place up for you!
(are we in trouble)?
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
