Old 10-13-2010, 10:45 AM
gossemer75 gossemer75 is offline
Vehicle: 2004 Dodge Ram
gossemer75 is on a distinguished road
Default 2003 seats in a 2004?
The drivers seat cushion in my '04 reg. cab ram is pretty well worn out. I found a full set of replacement with console from a 2003 ram, will these bolt up? even if I have to swap the mounting brackets?
Old 10-13-2010, 10:49 AM
oops! ok not sure how I did it, but I just noticed this is under gen. 1 rams... If it needs to be moved please do, thanks.....
Old 10-13-2010, 11:00 AM
Kens04's Avatar
Kens04 Kens04 is offline
Vehicle: 2004 Ram QC 4x4 HEMI
Trim Level: SLT OFF ROAD
Rep:48
Kens04 is on a distinguished road
I recently just bought a new cushion from the dealer, $72. Seems a little steep but well worth it. Thats with the employee discount, not sure how much but it was six dollars less than the one I found on ebay.
$72 seems like a deal compaired to removing all the seats. Took me five minutes to replace, just pull the three clips under the seat that hold the cover in place and pull out the old and install the new. A little elbow grease is needed to get the new cushion to sit all the way back over the frame, lean the seat back as far as you can to install.
Also when i removed the old cushion I tapped down all the welds on the seats metal frame and wraped them with some thin foam and cut some old jeans up to lay on the springs before installing the new cushion so it wouldnt wear as fast as the old one did...feels great now.
