2010 Dodge Ram lift questions - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-13-2010, 05:00 PM
Jliles0523 Jliles0523 is offline
Jliles0523 is on a distinguished road
Default 2010 Dodge Ram lift questions
Hey everyone,
I am new and now in the market for some kind of lift system to put onto my 2010 2wd dodge ram 1500 QC. From browsing around on the site, I have came up with 2 possible ways: (1st and most favorable) performance accessories 3" body lift and 2" leveling kit and (2nd) 7" CST 2wd lift. I know that these two differ some amount but i really like the look of the higher lifts alot more but I'm just not sure that i can afford it at the moment. So if y'all can, please post some pictures of either of these systems installed on yalls trucks, so i can get some ideas.
Also what is the biggest tire i can run, on stock 20's, with the 3" body lift and 2" leveling kit, preferably either toyo open country m/ts or nitto trail grapplers.
Thanks to anyone that can help!
Old 10-13-2010, 05:13 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Hello and welcome to the site. Got any Pics of your truck???
If your looking for some accessories check out our vendor section and may the modding continue
http://www.ramforumz.com/forumdisplay.php?f=53
Old 10-13-2010, 07:08 PM
Crawler Hauler Crawler Hauler is offline
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Crawler Hauler is on a distinguished road
Here's a video you might want to check out.
http://www.youtube.com/user/PerfAuto.../2/EiGbzcLrk6o
Old 10-13-2010, 07:36 PM
Rep:1625
I'd go with the 7" CST lift. Here are some pics of the CST kit installed:
Old 10-13-2010, 07:39 PM
ScatPak07's Avatar
Rep:970
I would go with the 7" CST if you have a 2wd truck. If you think about it the 4x4 trucks already sit higher then the 2wd trucks. So if you were driving a 4x4 the 5" lift would be like a 3" and the 7" like a 5". If you were to go with either one I think you will be able to fit 35" tires under there. I would recommend getting some aftermarket rims with a negative offset to bring the tires out away from the body.
Old 10-13-2010, 10:58 PM
Thanks everyone for the responses!
After reviewing all my options, (and looking at that blue ram with it installed) I have decided to go with the CST 7 inch lift. has anyone on here got one installed? Are they reliable? And on the ordering page it asks what rear lift height i would like 1 or 4? Could someone help me on this
Scat- Why would you recommend getting new wheels with negative offset? Would that make it so the wheels are more outside of the wheel wells?
Old 10-17-2010, 12:04 AM
Rep:1625
You'll want to get the 4" rear lift. Negative offset will help prevent rubbing; yes, the wheels would stick out further.
Old 10-17-2010, 10:29 AM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
If you don't get a negative offset your tires will rub.You would want at least a negative 12 offset on your rims.
Old 10-18-2010, 11:25 AM
moosey42 moosey42 is offline
moosey42 is on a distinguished road
Ive noiced that some have installed these lifts and use their factory wheels but used 1/4 wheel spacers and the 35 in tires fit.
