Old 10-13-2010, 08:09 PM
Rusty Nib's Avatar
Rusty Nib Rusty Nib is offline
Vehicle: 2003 Dodge Ram 1500 4x4
Rep:59
Rusty Nib will become famous soon enough
Exclamation I need torque specs! or: Haynes Manual Sucks
Howdy -
So I have just replaced a broken valve spring. Now I'm replacing what the Haynes Manual calls the "rocker arm shaft bolts", but Haynes doesn't have a torque specification for "rocker arm shaft bolts". It has a listing for "Rocker arm bolts" @ 16lbs and also a listing for "Rocker Arm Lifter Rail Bolts" @ 106 in-lbs.
Now, I think the latter is the correct listing, but I'd like to make sure!
Being as the terminology is not the same, I'm not sure which specification is correct. Can someone be so kind as to clarify from their own specifications?
I might be able to get this buttoned up tonight. Thanks ahead of time for your help!
Old 10-13-2010, 08:23 PM
RamTech RamTech is online now
Rep:1890
INSTALLATION
1 - PUSHROD RETAINING PLATE FASTENER 2 - PUSHROD HOLDER
CAUTION: The longer push rods are for the exhaust side, and the shorter push rods are for intake side.
  1. Install the push rods in the same order as removed.
  2. Install the pushrod retaining plate (1) special tool 9070.
    1 - ASSEMBLY TANG 2 - RETAINER ( FULLY SEATED ) 3 - SPACER 4 - ROCKER ARM
    CAUTION: Ensure that retainers (2) and rocker arms (4) are not overlapped when torquing bolts.
    CAUTION: Verify that pushrod is installed into rocker arm (4) and tappet correctly while installing rocker shaft assembly. Recheck after rocker shaft has been torqued to specification.
    CAUTION: The rocker shaft assemblies are not interchangeable between intake and exhaust. The intake rocker arms are marked with the letter I.
  3. Install rocker shaft assemblies in the same order as removed.
  4. Tighten the rocker shaft bolts to 22 Nm (195 in. lbs.) torque,using the sequence provided. CAUTION: DO NOT rotate or crank the engine during or immediately after rocker arm installation. Allow the hydraulic roller tappets adequate time to bleed down (about 5 minutes).
  5. Remove pushrod retaining plate (1) special tool 9070.
  6. Install cylinder head cover.
Old 10-13-2010, 08:33 PM
Rusty Nib's Avatar
Rep:59
Thanks again Randy - You are the MAN!
Old 10-15-2010, 07:14 AM
thirdmouse's Avatar
thirdmouse thirdmouse is offline
Vehicle: 1994 Ram 1500
Color: red
Rep:25
thirdmouse is on a distinguished road
Don't you know - Haynes stands for Hardly Anything You Need or Ever See.
This truck is brought to you today by the letter V and the number 8.
Old 10-16-2010, 07:18 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
damm randy where you getting all these manuals and what not
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 10-16-2010, 08:08 PM
I push the skinny pedal
Rep:3277
Well, he IS a chrysler tech! More great info there Randy.
Kurtis
Old 10-16-2010, 08:38 PM
Rep:1890
Yup, straight from the horses mouth, so to speak.
Old 11-10-2011, 03:28 AM
Jorde's Avatar
Jorde Jorde is offline
Vehicle: 2011 Ram 1500
Trim Level: sport
Color: silver
Jorde is on a distinguished road
click link to download...enjoy!
http://mcfail.net/dt/Service%20manual.zip
