Old 10-13-2010, 08:15 PM
mctaggart's Avatar
mctaggart mctaggart is offline
Vehicle: 2010 Big Horn
Color: Blue
mctaggart is on a distinguished road
Default Leveling Kit need to know ASAP
Can I fit 33's with a 2.5 leveling kit. I am looking to put on toyo m/t
Old 10-13-2010, 08:16 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Yeah, you should be fine. How wide are they though?
Dillon-aka, The Little Kid
Old 10-13-2010, 08:27 PM
mctaggart's Avatar
Color: Blue
12.5. I have been reading lots about them but it goes both ways some say 35's will fit with a 2.5.
Old 10-13-2010, 08:34 PM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
The factory 275/60/20 tires are technically a 33" tire. Of course like GeauxHunting said, you need to know the width.
You might benefit from this site (I use it all the time...) : http://www.rimsntires.com/rt_specs.j...ize%20comparer
Plug in your factory tire size specs, and then input whatever size you're looking at. Gives a good comparison between the 2. Make sure to use the correct rim specs too.
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 10-13-2010, 08:42 PM
mctaggart's Avatar
Color: Blue
Awsome thank you. Great site
Old 10-14-2010, 09:02 PM
ScatPak07's Avatar
Rep:970
Ya you should be alright with those tires. The 12.5 might be real close. I know a guy with 305s on his truck and it is stock (33" high) and he has no problems. Now with an extra 1" to the width you never know if that will cause a rub. with the level you should be alright though
Old 10-14-2010, 09:36 PM
mctaggart's Avatar
Color: Blue
Some people told me it would work and some say no. I figure ramforumz is the best way to find out. I enjoy seeing what other 2010 ram owners are doing to there rides.
Old 10-14-2010, 10:23 PM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
With out knowing the clearance on the new trucks i can't say for sure on the 35's i had them on my 2005 with a 2" level kit and they rubbed only at full lock, so i would assume you could get away 35x12.50x20 on a 2010 if you wanted slight rubbing....my tires where actually larger then 35 and wider then 12.5.
As for 33x12.50x20 the stock tires are 33" just narrower so i don't think you will run into any problems!
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 10-14-2010, 10:29 PM
srt93 srt93 is offline
Vehicle: 2006 dodge ram 1500 4x4
Trim Level: laramie
Rep:55
srt93 will become famous soon enough
i have a two inch revtek levelling kit on my 06 and i have 35x12.50R18s on aftermarket rims on 4.5 backspacing...they rub a decent amount probably would be better off with 5 inch backspacing and there has been one time i was climbing out of a ditch where i saw as the suspension articulated inwards it rubbed on the fender well but barely nothing would get wrecked by it....and i have read of guys running 35's on 2010's with no levelling kits.
