Quoted $1373.50 for alignment after Installing Leveling Kit - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-14-2010, 12:03 AM
doozy doozy is offline
Vehicle: 2007 Mega Cab 5.9L Cummins
Trim Level: SLT 2500 4x4
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
doozy is on a distinguished road
Default Quoted $1373.50 for alignment after Installing Leveling Kit
2007 4x4 with 85k miles. 5.9 Cummins with 35x12.5x17 tires.
I've owned this truck for about 2 months. When I bought it, it already had a 2" Revtek leveling kit installed. I just put brand new tires on it so I thought it would be a good idea to have it aligned. The shop I normally use has alignment racks that do not handle "long beds" so I took it to Tires Les Schwab (west coast HUGE tire retail chain). They called and said they couldn't align it because it needs:
2 Offset Ball Joints
1 Inner Tie Rod End
1 Tie Rod End
1 Outer Tie Rod End
2 U Joints
The quote after tax is $1373.50 AND I'M CALLING BS!
My U-Joints supposedly have rust on them, but since my rig is only about 3 years old, I'm sure it surface rust and I highly doubt they need replacing. As far as the rest goes, I'll crawl under it myself and see what it needs. My main question is on the offset ball joints. Are these custom ball joints so my rig will align to spec with the 2" leveling kit? Are they needed with other leveling kits or lift kits? I'm not opposed to taking this leveling kit off an starting over if I have to.
Thanks
Jeff
Vancouver, WA
jh
Old 10-14-2010, 12:25 AM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
Ya that's way overpriced, i just got an alignment done about 2 months ago for $60.
Carven exhaust, K&N CAI, Leveled with wheels and tires, Sundown & Skar audio.
Old 10-14-2010, 12:31 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
A second opinion is in order......just don't tell them what the first guys said....
brad
Interested in one of my mods?
Old 10-14-2010, 12:42 AM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
I'm going with brad12kx on the second opinion... and if it infact will need the parts... I'd have someone else do it. That sounds a bit excessive for parts and labor.
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 10-14-2010, 08:18 AM
Resident Technician
Rep:1915
Offset ball joints are indeed meant to correct camber issues on straight axle trucks but it's rare that they're needed. Rust on the outside of a u-joint is NOT a reason for replacement. I also doubt that all your tie rod ends are bad unless you've really beat this truck up off road.
Old 10-14-2010, 08:23 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
I agree, get another opinion...
Old 10-14-2010, 02:51 PM
Crawler Hauler Crawler Hauler is offline
Crawler Hauler is on a distinguished road
The tie rod ends and ball joints are common weak links in the diesels. They tend to wear out faster with bigger tires.
They also seem to have more allowable play in them than other trucks. When I had my last set of tires put on they told me I needed new tie rod ends. I took it to a diesel performance shop near me who told me that the front end was within spec for a Dodge.
I'd go there. A diesel performance shop that deals with lifted Dodges on a regular basis.
Old 10-14-2010, 10:26 PM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
YA that sounds very ridiculous for s truck as new as yours! get another opinion like everyone has said...i can't see a leveling kit throwing out your alignment so bad you need offset balljoints....i just put a 5" lift in my 1500 with IFS and the alignment wasn't out too terrible!
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 10-26-2010, 11:58 PM
rmorgan482 rmorgan482 is offline
Vehicle: 17' Ram 2500 4x4 6.7
rmorgan482 is on a distinguished road
You have to be careful about taking your truck to shops like those. It seems like everytime I take mine to Brake Check or another national chain they always find something that "needs to be replaced". Same thing happend to me, they told me there was too much play in my wheels and I needed new ball joints, tie rod, and wheel bearings. In fact it was the idler arm that was causing the issue.... Best thing to do is get multiple opinions and find a shop that deals with lifted/offroad vehicles often.
Old 10-27-2010, 12:07 AM
moparmanicac's Avatar
moparmanicac moparmanicac is offline
Vehicle: 12 RAM 1500 qc 4x4 HEMI
Trim Level: express
Color: bright silver
Rep:204
moparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura about
I honestly would never take my truck to any large chain (unless ya count a dealer as a chain) after I got my last truck lifted if it was any sort of work that I didnt 100% know what I needed to be done it would go to a 4x4 shop or a shop that I knew had seen many a lifted truck
[SIGPIC] RIP 02 4.7 Dakota sport qc 4x4
RIP 05 Ram 4.7 rc 4x4
HELLO 12 Ram HEMI qc 4x4 and 94XJ
