OEM brake controller flash - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 10-14-2010, 11:29 AM
Jgroes Jgroes is offline
Jgroes is on a distinguished road
Default OEM brake controller flash
Looking for an answer regarding flashing after installing an OEM brake controller for a 2010 1500 CC 5.7L. Specifically, what chip is flashed after installing the brake controller?
I ask because I know youll get charged if you take it in to the dealership just for that reason. Im thinking it will be the PCM that is flashed for the controller to get picked up in the EVIC?
Im taking my rig in for the HVAC Control Module Programming recall and am not sure if a flash is required after the fix, and if so, will the flash cover the brake controller install. Im thinking the recall flash will be for the BCM, vice the PCM?
Thanks,
JG
Old 10-14-2010, 11:48 AM
Resident Technician
Rep:1915
If there are any flashes available for your truck while under the 3/36k warranty, there should be no charge. The brake controller does need to be added to the build configuration and then the TIPMCGW must be updated (they may charge for this part). Your truck doesn't have a BCM.
