Old 10-14-2010, 08:48 PM
macsbees's Avatar
macsbees macsbees is offline
macsbees is on a distinguished road
Default DPF Delete
I am planning on doing the DPF Delete in the very near future.
Is there any difference between just a DPF delete pipe or turbo back exhaust?
I am debating the two and you guys/gals can help me make that call.
TY
Old 10-14-2010, 10:11 PM
Torq89 Torq89 is offline
Vehicle: 2005 Ram 2500
Color: Grey
Rep:87
Torq89 will become famous soon enough
Go with the turbo back! Get's rid of all the BS emission crap you dont need
Old 10-15-2010, 01:17 AM
I push the skinny pedal
Rep:3277
I would try to get a large bore turbo-back kit if you can, but that may be difficult to do with a 6.7L. If you do get just a delete pipe, you'll still be running the stock diameter, which is restrictive if you're planning on some major mods to the diesel. Also, what tuner are you planning on running to handle the DPF delete? I would recommend the H&S Mini MAXX.
Kurtis
Old 10-15-2010, 02:21 AM
macsbees's Avatar
I will be running the new Smarty when it is released. I was thinking of a 4" or 5" turbo back to get rid of most of the crap attached to the stock exhaust systems.
The DPF delete system will still run all stock. My main concern is if there is a difference.
