Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 10-16-2010, 02:45 PM
road383runner road383runner is offline
road383runner is on a distinguished road
Default no coolant pressure and no heat
96 ram 2500 4x4 360 engine i replace heater core, water pump, thermostat, all hoses, radiator, flush both ways engines does not build up coolant pressure and no heat. Truck runs at normal temp doesnt over heat can drive it all day and the radiator stays cool from about 3 inches from top hose over to passenger side and bottom hose is cold Thanks
Old 10-16-2010, 03:44 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Gotta ask, when you say you flushed it both ways, was that through the radiator or just the heater core?
No oil in the radiator and on water in the oil?
Brian:
Old 10-16-2010, 04:26 PM
Mtx's Avatar
Mtx Mtx is offline
Vehicle: 97 Dodge 2500
Trim Level: 2500 4x4
Color: hunter green
Rep:16
Mtx is on a distinguished road
i see where your going^.
does it lose any coolant at all? also could be bad radiator?
Old 10-16-2010, 04:30 PM
No doesnt lose any coolant. i was thinking of putting old radiator back in to try it to see if new one is bad
Old 10-16-2010, 04:34 PM
i tap into both heater hoses and flush with drain plug out of radiator and with plug in radiator. no drip stick is clean just oil and no oil in radiator
Old 12-05-2010, 11:22 AM
Cloud22 Cloud22 is offline
Vehicle: 1996 Dodge Ram
Cloud22 is on a distinguished road
i am having the same problem with mine i have replaced the rad, thermostat(x2),rad cap , flushed the heatercore, everything worked fine for a week and now its back to freezing again also after running for well over an hour i can still take the rad cap off and stick my finger in the coolant its barely hot
Old 12-05-2010, 12:41 PM
BigThirsty's Avatar
BigThirsty BigThirsty is offline
Vehicle: 2004 Dodge Ram 2500 4X4
BigThirsty is on a distinguished road
I don't know what the stock temp is on the thermostat but if everything is working fine, I would look at getting a hotter thermostat.
I have the same problem with my 98 Ford Taurus. I recently had the entire engine and cooling system replaced and now it runs too cool not allowing the heater to get very warm even though, as I am told, "it is operating within factory specs". A simple fix is to put a piece of cardboard in front of the radiator to slow down the air flow.
I would ask if your clutch is locked on your fan causing it to pull all the time but even if this were the case, the thermostat should stay closed until it reaches the proper temp.
2004 Dodge Ram 2500 4X4 5.7
