Minimal Heat - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Old 12-02-2010, 04:37 PM
redram1500 redram1500 is offline
Vehicle: 98 Ram 1500 St. Cab Lg Bed
Color: Med. Red
redram1500 is on a distinguished road
Default Minimal Heat
Hello all
I have minimal heat in my 1500 5.2L. It's warm enough to tolerate the winter here in Illinois. I wanted to ask though; I sometimes hear some gurgling or water type sound when I turn on the defrost. This doesn't always happen. Not even at regular intervals and its always been far enough apart and for short enough time I haven't bothered looking into it or forget. I don't have a problem with fogging windows or anything so I don't think the heater core is blown. I suppose could be partially clogged.
Any suggestions to look at or ideas as to the cause would be great.
Old 12-02-2010, 04:43 PM
Rep:1915
How's the coolant level and what's the operating temp of the engine? Are both heater hoses getting hot or just warm?
Old 12-02-2010, 04:46 PM
Color: Med. Red
Coolant level is good, engine temp gets to the 170 180 range and the hoses feel normal. I did put cardboard in front of the radiator which pushed it up to around 200 engine temp and I get a little more warm air, but not much. Also, it takes 20 minutes of 60 MPH to get it up to that 200 temp. I don't have a thermometer to put on the vent, but it isn't near as warm as it should be, maybe 1/3 as hot as it should be.
Old 12-02-2010, 05:52 PM
Rep:1915
Sounds like a stuck open thermostat at this point.
Old 12-02-2010, 06:29 PM
Thetolleyman Thetolleyman is offline
Vehicle: 2003 Ram 1500 Quad Cab
Color: Gold/Silver
Thetolleyman is on a distinguished road
I agree, a stuck thermostat. There cheap just replace it. The gurgle noise is normal for some vehicles, but could indicate low coolant level, perhaps needs to be bled of air.
[03' Ram, K&N FIPK, Electric fan conversion, Fast Man TB, Superchips tuner, Magnaflow cat-back, 08' intake, 1" body lift, 1.5" coil spacers, 3" lift spindles, 1 1/2" block on rear, rear leaf flip,. [/SIZE]
Old 12-02-2010, 07:28 PM
RootBeer RootBeer is offline
Color: RootBeer
Rep:1287
With a 98 Ram, I'd have to go with the t-stat too. When was the last time it was replaced and the whole cooling system flushed?
Brian:
Old 12-03-2010, 11:40 AM
Color: Med. Red
Unsure when it was last flushed as I have only owned for a few months. The coolant looks brand new though, bright green. I'll check the thermostat if I get time. Thanks for the suggestion.
