Old 10-19-2010, 02:07 PM
Leadchunker's Avatar
Leadchunker Leadchunker is offline
Vehicle: 1996 Dodge Ram 1500 4x4,
Color: Green
Rep:57
Leadchunker will become famous soon enough
Default Lift Kit
Thanks, I will check out the BDS lift and the 3" Rough Country
Chuck
Lawrenceville, GA.
Old 10-19-2010, 10:13 PM
MoparMadness MoparMadness is offline
MoparMadness is on a distinguished road
I have a 95 swb 1500 on 315/75/16 (about a 35" tire) with 3" skyjacker coils up front and an add a leaf in the rear, pro comp rs 9000 shocks bought it all for around $350 sepratly from ebay (coils) and summit racing (add a leaf and shocks) you could also get coil spacers instead and save some money
Old 10-21-2010, 06:50 PM
Color: Green
Rep:57
Thank you MoparMadness, I will do some checking for seperate parts and see what I can come up with as well. That rough country set up is looking pretty good.
Chuck
Lawrenceville, GA.
Old 10-21-2010, 07:37 PM
I wish I would have went taller (but any taller with the suspension and you have to change the pitman arm and control arms) im thinking about adding a body lift
Old 10-24-2010, 09:29 PM
FloridaCracker352's Avatar
FloridaCracker352 FloridaCracker352 is offline
Vehicle: ram 1500 extcab 4x4 1998 dodge
Trim Level: larmine slt
FloridaCracker352 is on a distinguished road
Send a message via AIM to FloridaCracker352
i would just get a 2.5inch leveling kit thats what i have on my 98 dodge 1500 ext cab short bed and i have 315-70-17 pro comp all terrains, i had no clearance issues only if i turned the wheel too far the tires would rub on the radius bars so i adjusted my steering stops out so they would no longer rub
Old 10-24-2010, 10:38 PM
fabtech makes great products
Old 10-26-2010, 01:47 PM
mnghouse mnghouse is offline
mnghouse is on a distinguished road
dont know if this helps but my old 98 1500 only had a 2 inch spacer up front and a 2 inch block in the back and I had 315 75 R16's on it (thats a 35) truck looked good too.
Neil
Old 10-28-2010, 02:23 PM
gatorguyrye gatorguyrye is offline
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
gatorguyrye is on a distinguished road
I have a '95 ram 2wd single cab short bed, i want to lift up the rear to sit even, are shackles for the rear leafs the best way to do that?
Old 11-01-2010, 09:21 AM
sbsg2005 sbsg2005 is offline
Vehicle: 2001 Dodge Ram 1500 sport 4x4
Color: blue
Rep:23
sbsg2005 is on a distinguished road
i have a 01 sport with a skyjacker 5.5 inch kit and clear 37 in mud grapplers with ease and the truck still rides better than stock
