squiky noisy engine - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 10-17-2010, 07:05 PM
jacksonbase jacksonbase is offline
jacksonbase is on a distinguished road
Default squiky noisy engine
Hi
I just bought a 96 2wd ram 1500. 97k miles. 318 runs good. It does however squik i guess at idle. Just kind of noisy at idle under the hood. It also has a psst (like an air comprssor going off) when the truck is turned off. The noise sounds also like a noisy belt but a new serpentine has been put on recently. It is uneffected by turning the a/c on and off.
This is my first Dodge so I'm new to any dodge qwerks.
Does the pully tensioner need replacing?
I'm looking for a place to start.
thanks
Jacksonbase
Old 10-18-2010, 11:57 PM
NuclearRam's Avatar
NuclearRam NuclearRam is offline
Vehicle: 2001 Ram 1500
Trim Level: Laramie SLT Quad Cab
Rep:20
NuclearRam is on a distinguished road
My first guess would be a faulty IAC...but that should generate a check engine light if that were the case.
If there's a hissing sound, it may be a leak in one of the vacuum lines.
Old 10-19-2010, 03:06 PM
Default squealing
No codes have been generated. Also noise only appears after truck has warmed up. I replaced belt and checked tensioner (looked ok) Also spun all pullys that can spin and all felt pretty good. I'm starting to lean tword fan clutch and or water pump. THe pump shaft had I guess 1/8" or less play in it but I guess could be going bad. any thoughts?
Old 10-19-2010, 08:16 PM
Take the belt off . Start it up and see if the noise is gone . That will help you detemine if it's fan belt related noise .
Old 10-22-2010, 01:02 AM
97ram1500 97ram1500 is offline
Vehicle: 2014 Dodge Ram
97ram1500 is on a distinguished road
if it is fan belt related it may be A/C compressor bearings going
Old 10-28-2010, 11:45 AM
Default squik
OK ive replaced the water pump and fan clutch and i thought noise went away. It has come back but louder. It is definitely something belt driven but I cant seem to isolate. it is driving me crazy. all belt driven accesories work fine (ps pump-ac-alt) I'm leaning tword the ac bearings? the noise is still there wether ac is on or off.
Noise only starts once engine has warmed up
goes away above 1500 rpm
lastly it kind of sounds like an air pump turning off -when engine is turned off (like a pffst sound?)
I really dont want to start replacing everything need help
thanks
Jacksonbase
Old 11-01-2010, 02:03 PM
Default noise
Well I went ahead and replaced the tensioner and pully. Knock on wood that fixed the squik. I still never really isolated the noise during my search.
Old 11-10-2010, 07:38 PM
aftershokk86's Avatar
aftershokk86 aftershokk86 is offline
Vehicle: 01 ram 1500 ext cab
aftershokk86 is on a distinguished road
so is it still making the squeaking noise?
01Ram: infinity reference 6x9's/5.25's|kicker 12cvt|400w4channelamp|2500wmonoamp|
Old 11-15-2010, 05:16 PM
Default squik
Well It did squik once or twice after I installed the tensioner (not nearly as loud just briefly) 3 weeks later no squiks!
Old 11-23-2010, 10:16 PM
MoparMan76 MoparMan76 is offline
Vehicle: 98 Dodge Ram 1500
Color: BLUE
MoparMan76 is on a distinguished road
Im glad to hear your not having any more squeaks. The tensioner is usually the first to cause issues. I was going to point out a cheap way to isolate noise locations is to use a form of stethoscope, staying off any moving parts and away from them as well, but you can get close enough within a few inches of a pulley safely and should be able to hear it if its squeaking.
If you don't want to stand behind our troops, feel free to stand In front of them!
