Rev limiter? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Tuning Discussion > Diablo Predator Questions & Info!
Old 10-17-2010, 09:32 PM
gonzo1's Avatar
gonzo1 gonzo1 is offline
Color: Mineral Gray
Rep:17
gonzo1 is on a distinguished road
Default Rev limiter?
Got my predator saturday and I set my rev limiter at 6000. Feels like I could set it higher but dont know what is to high for the 4.7L motor. But it feels like it is still pulling when it shifts at 6000rpm's! Trying to find out what others are setting their's at for best performance. Also I don't have the MDS or tire size option on my predator and don't know why. Can anyone maybe tell me why? (U7137 is what I have)
Old 10-17-2010, 09:58 PM
Well your 4.7 doesn't have MDS .
Old 10-17-2010, 10:05 PM
gonzo1's Avatar
Color: Mineral Gray
Rep:17
Oh ok. Didn't know that. Thought it did since I see ECO go in and out on the dash and thats when I thought it dropped cylinders. Thanks!
Old 10-23-2010, 06:47 AM
Ramathorne Ramathorne is offline
Vehicle: 2013 Dodge Ram 1500 Quad Cab
Color: Mineral Gray
Rep:54
Ramathorne will become famous soon enough
I can't set mine higher than 5850rpm on my 2010 Hemi
It cuts out or something between there and 5900rpm regardless of where I set it above
Old 10-23-2010, 12:30 PM
MADDOG MADDOG is offline
Rep:22
If you set the rev limiter higher than redline that may stress the engine.
On the U7137 tool you should be able to set WOT shift RPM. If not, the guys at DiabloSport can send you a file that you add to the tool and use it to set that parameter.
I set my WOT shifts at about 200 RPM below redline just to insure it shifts at the right point (TCM communications to PCM can lag a bit and the RPM's may go past the shift point before comms are complete) so it don't bump the limiter.
Keep in mind that your redline may not be the optimum shift point because by the time you get there, your HP & torque numbers are probably already beginning to drop off. If you can find the sweet spot on those curves, where they max out, that's your RPM shift point.
Old 10-23-2010, 08:15 PM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
6k on a 4.7 seems high.....these motors make power at lower speeds then HEMI's.....i would think you would get better results if you could make it shift sooner then stock....jm2c
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 10-23-2010, 10:52 PM
ScatPak07's Avatar
Rep:970
I didnt even touch my rev limiter. I let the pre loaded tune do all the work.
