Old 10-18-2010, 12:17 AM
ram 98 318ci ram 98 318ci is offline
Vehicle: 1998 Dodge Ram SLT Laramie
Color: Green / Silver
Rep:22
ram 98 318ci is on a distinguished road
Default Trans fluid change
I found out that my trucks tranny fluid has not been changed in 60k miles so this is a MUST and will be done this weekend, how bad is this or is it fine just dont let it happen again?
Old 10-18-2010, 09:03 AM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
Im not a expert by any means. Changing the fluid now isnt going to hurt anything. Im sure your tranny will thank you for it.Is it still working fine?
Old 10-18-2010, 09:34 AM
Smoke07 Smoke07 is offline
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Smoke07 is on a distinguished road
I just did mine this weekend - not a tough job at all. I have a 2500 and didn't need to lift the truck at all, plenty of room. I have 48k on my 07 CDT and it was slipping on cold mornings going into reverse and then between 1st and 2nd. tightened up the reverse tension band yesterday (1st to 2nd will be done tonight)- and this morning it's working great! the ATF did smell a little burnt - nothing horrible and there was only a small amount of "sludge" on the tran pan magnet. used the original plastic gasket and no leaks at all. good luck!
Old 10-18-2010, 04:21 PM
Rep:22
thanks i will change it this weekend and will more than likely put a new gasket on it.
Old 10-18-2010, 07:06 PM
I would recommend to ya , to install a good quality synthetic tranny fluid like Amsoil . It has made a believer out of me . If your 4x4 , don't forget to changeout your transfer case oil also .
Old 10-18-2010, 08:36 PM
Rep:22
will do nice synthetic one with the added lube?
Old 10-18-2010, 08:57 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
I only run Mopar ATF+4. I have had problems with other brands, and since none of them want to pay for a tranny rebuild, I went back to Mopar.
Old 10-19-2010, 09:29 PM
Rep:22
true ty guys
Old 11-10-2010, 10:15 AM
Rep:22
did it all and the cork was a pain to get off but its all clean and put back together
Old 11-11-2010, 08:55 PM
jason3506's Avatar
jason3506 jason3506 is offline
Vehicle: 1999 ram 1500
Color: silver
Rep:19
jason3506 is on a distinguished road
Talking manual fliud?
does a manuel take the same fluid?
Jason
