Old 10-18-2010, 01:03 PM
sly96ram's Avatar
sly96ram sly96ram is offline
Vehicle: 1996
Trim Level: larmie slt 1500
Color: green and silver stripes
sly96ram is on a distinguished road
Default Throttle Cable Modification EXTRA POWER!
Well I not for sure if there is a right up about this with the 2nd gen rams 5.2 and 5.9 so I figured i would start one. I decide to buy a CAI the other day and wile installing it i notice something up at the throttle cable I had tons of slack. So i decided to test a theory. I put a rock the gas petal till it was smashed to the floor and notice the thottle body was only opening halfway.
So if you look at were the cable attached to the pedal you will notice you can pull all the slack through. I used a small cable clamp i got for 65 cents to take up the slack and hold it in place on the pedal. Now the throttle response is great and It actually gots a lot more power instead of only half. I also noticed it now down shifts when it needs to.
Old 10-18-2010, 01:36 PM
RamTech RamTech is online now
Rep:1885
This is more of a repair than a mod since it's now working as it was originally intended.
Old 10-18-2010, 01:45 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
RamTech has a point
Dillon-aka, The Little Kid
Old 10-18-2010, 01:50 PM
sly96ram's Avatar
Vehicle: 1996
Ya and its a modification to the cable instead of replacing the cable.
Old 10-18-2010, 01:51 PM
hauser775's Avatar
hauser775 hauser775 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: SLT Laramie
Rep:67
hauser775 will become famous soon enough
Did this on my old 94' Ranger. Works quite well. I used a zip-tie rather than a clamp.
Old 10-18-2010, 07:53 PM
I will have to check out mine . Thanks .
Old 10-22-2010, 01:00 AM
97ram1500 97ram1500 is offline
Vehicle: 2014 Dodge Ram
97ram1500 is on a distinguished road
isn't there an adjuster nut that can adjust the tension on the cable?
Old 10-22-2010, 09:54 PM
Paul89's Avatar
Paul89 Paul89 is offline
Vehicle: 1998 Dodge Ram 1500
Rep:20
Paul89 is on a distinguished road
You would think there be an adjuster nut on the cable. Be checking mine in the morning.
Old 10-27-2010, 05:46 PM
Joe Daddy Joe Daddy is offline
Vehicle: 1995 Ram 1500 4wd ext 5.2
Joe Daddy is on a distinguished road
I couldn't find 1 but a 2lb hammer will adjust the bracket nicely, also helps with down shifts!
Old 11-17-2010, 11:05 PM
zmer550's Avatar
zmer550 zmer550 is offline
Vehicle: 1995 Dodge Ram 1500 4x4
Color: Dark Green
Rep:68
zmer550 will become famous soon enough
Send a message via MSN to zmer550
did it to mine this morning, it works!
318 R/T = All Show No Go Rusty Truck
