Old 10-18-2010, 02:41 PM
DatWunGai's Avatar
DatWunGai DatWunGai is offline
Vehicle: 2005 Dodge Ram 1500 4WD
Color: Mineral Gray Metalic
DatWunGai is on a distinguished road
Default Specific rim/tire combo question...
Hey everybody!
I have an 05, leveled, 4x4, QCSB with stock rims and tires (20x9-275/60/R20). I reeeeally like Factory Reproduction's satin black Viper wheels but I'm not sure which way to go...
Do I stick with the same size wheel/tire combo as stock or can I go with a 20x10-305/55/R20 Cooper Zeon LTZ setup with out rubbing?
The offset difference between the two is 1mm, so the main difference is a wheel/tire combo that is 1/2 inch wider at the inside and outside of the wheel. Will this rub?
Thanks in advance!
2005 Ram SLT, QCSB, 4x4, 5.7L Hemi, Flowmaster, K&N
Navy Vet - U.S.S. Fletcher DD-992 (1990-1994)
Old 10-18-2010, 02:49 PM
Rep:2657
if you go to either the Discount Tire or the Tire Rack website, you can insert your vehicles info & the size & type of tire/wheel combination in there also, if its compatible, it can be seen on your vehicle, same color & all
if its not compatible, it will tell you that also
Old 10-18-2010, 04:34 PM
DatWunGai's Avatar
Thanks for the advice; I've actually already done that, and it doesn't recommend any 10" wide wheels, but I'm wondering if I can get away with 10's since my truck is leveled?
