Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 10-18-2010, 07:19 PM
jnr7510 jnr7510 is offline
Vehicle: 2000 dodge ram 1500
Trim Level: 4x4 reg cab 5.2
Color: blue
jnr7510 is on a distinguished road
Default Speed sensors Really need help!
Ok I have a 2000 dodge ram 5.2 and the other day my speedo stoped working and also the odomoter went out. Then the check engine light came on and also the abs light came on as well.I was told it was the rear speed sensor on top of the diff that went out so I changed it and nothing was diffrent. Then I was told it was the speed sensor right by the transfer case it was out bound speed sensor or something like that so I changed it and still nothing. My breaks work fine. I dont know what else to do. Is there something simple that I am missing? Please help
Old 10-18-2010, 07:21 PM
Color: blue
Oh also they said there was one code that was p0500. It said it was the A sensor?
Old 10-18-2010, 07:39 PM
Resident Technician
Rep:1915
And that's the only code in any of the modules? It could be the sensor, wiring, ABS module, PCM...difficult to say without diagnosing it.
Old 10-18-2010, 07:53 PM
Color: blue
Is there any other sensors any where else?
Old 10-18-2010, 08:13 PM
Resident Technician
Rep:1915
Sure, but they won't be the problem.
Old 10-18-2010, 09:52 PM
Color: blue
So do you think it might be a computer problem?
Old 10-19-2010, 01:58 PM
yamarider yamarider is offline
Vehicle: 1998 Dodge Ram Quad
yamarider is on a distinguished road
I had to replace mine too for the same issue - I replaced the one on the rear end. Disconnected the negative side of the battery for 15 min. Hooked up new sensor and rehooked up negative side and worked like a champ. Hope this helps.....
Old 10-20-2010, 04:38 PM
ram 98 318ci ram 98 318ci is offline
Vehicle: 1998 Dodge Ram SLT Laramie
Color: Green / Silver
Rep:22
ram 98 318ci is on a distinguished road
i did the same as yamaha rider it would only work if i went over 35 mph so i chnaged the rear sensor and it worked fine, try to unplug the battery like yamaha said
