Old 11-09-2010, 12:11 AM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
Thanks again all! I appreciate the kind words! The tires impressed me a bit last weekend... After a buddy and I went target shooting, we decided to off-road a little. No mud right now, but we put the Ram in 4 low and took it up a decent grade hill and the tires didn't slip at all. Almost seemed too easy!
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 12-08-2010, 03:15 PM
hotrod929 hotrod929 is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: Outdoorsman
hotrod929 is on a distinguished road
do you have any rubbing at full lock with those rims and tires? also how much is the back spacing on those rims? thanks
HotRod
Old 12-11-2010, 02:08 AM
Rep:147
HotRod
No rubbing at all at full lock! In fact, there is room to spare for some slightly wider tires in the future. With an 18x9 rim (rim width is important when discussing backspacing/offset) and +10 offset, you are looking at between 5.25 to 5.5 inches of backspacing. I did not want to go over 5.5". I believe stock is a bit over 5.5 or 5.75 inches. I went with a higher numbered offset in order to decrease the backspacing and set the tires away from the upper shock mounts (and inner fender wells) since they are wider.
wheels tires gear hankook
