Wind Noise - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 10-19-2010, 07:58 AM
rbu1 rbu1 is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: Crew Cab
rbu1 is on a distinguished road
Default Wind Noise
Does anyone notice a decent amount of wind noise when driving at highway speeds? It seems to be coming from the passenger side.
Old 10-19-2010, 08:05 AM
Resident Technician
Rep:1915
You may have a body panel out of alignment. You can put masking tape over the gaps and drive the truck to see if the noise goes away.
Old 10-19-2010, 08:14 AM
Good suggestion ^^^ !
I had that problem on my '99 and it was a folded over, stiff and cracked door seal. I replaced it and no more noise.
Old 10-19-2010, 08:43 AM
Would a panel out of alignment be something you could visually see?
Old 10-19-2010, 08:44 AM
Resident Technician
Rep:1915
Not always. That's what the tape test is for. If the leading edge of a door is sticking out farther than the trailing edge of the panel in front of it, you'll get wind noise.
Old 10-19-2010, 08:53 AM
OK is that an easy fix if it is an alignment issue? I would rather deal with the noise if they have to do anything major...
Old 10-19-2010, 08:56 AM
Resident Technician
Rep:1915
Depends on what might need adjusting. I'm no body man so I can't say for sure.
Old 10-19-2010, 09:48 AM
OK thanks for the help
Old 10-19-2010, 08:31 PM
rtkman's Avatar
rtkman rtkman is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Rep:167
rtkman has a spectacular aura aboutrtkman has a spectacular aura about
Typically wind noises are easily repaired by adjusting a body panel or sealing up a seam / missing foam piece under the mirror etc. Its usually routine and no big deal. Water leaks can be another issue all together but wind noise is usually simple for a qualified body tech.
Old 10-19-2010, 10:56 PM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
had the same issue....mine was a windsheild seal on the driver side....looked like someone bumped the robot and it deviated from its course.....resealed it and problem gone....catcher is that is was also a water leak but normal rain wouldnt come in.....hose pipe on the other hand.......if you hear wind noise in the truck id bet you have a leak somewhere.....jm2c!
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
