Old 10-19-2010, 09:33 PM
stisam80 stisam80 is offline
Vehicle: 2006 2500 hemi
stisam80 is on a distinguished road
Default 6.1 intake manifold
Hey guys I was wondering if the 6.1 hemi intake manifold well fit my 5.7 hemi?
Old 10-19-2010, 10:52 PM
I push the skinny pedal
Rep:3269
They will bolt up, but the ports don't match up correctly and would require quite a bit of grinding/polishing to port everything so it'll match up without having the lip that would restrict airflow.
Kurtis
Old 10-19-2010, 11:01 PM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
huh...i was under the impression they wouldnt
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 10-19-2010, 11:38 PM
Rep:3269
Direct quote from S-A Designs High Performance HEMI builders Guide pg. 71-72:
some enthusiasts have swapped the 5.7L's composite, long-runner intake with the 6.1L's aluminum manifold, which features shorter runners. But with the 6.1L manifold fits the 5.7L, it is of limited effectivness without additional performance modifications to support its air-flow design. An upgrade to increaded flow cylinder heads, a supercharger, or nitrous-oxide would compliment the 6.1L manifold.
A caveat to using the 6.1L manifold: without proper tuning, the 5.7L's computer won't like it.
Hope it helps.
Kurtis
Old 10-23-2010, 05:06 PM
NewToDodge's Avatar
NewToDodge NewToDodge is offline
Vehicle: 2006 Ram 1500 5.7L Hemi
NewToDodge is on a distinguished road
I will have to keep this info in mind when I start looking at super chargers...
Mod List: Diablo Sport: Trinity,
Old 10-23-2010, 10:18 PM
DeepWaterHemi's Avatar
DeepWaterHemi DeepWaterHemi is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Trim Level: SLT Sport
Color: Deepwater Blue PBS
Rep:276
DeepWaterHemi is a jewel in the roughDeepWaterHemi is a jewel in the roughDeepWaterHemi is a jewel in the rough
Don't know if this helps but I know a quite a bit of chargers and challengers with the 5.7/6.1 manifold swap with "Crank This Motorsports" adapter kit. Never heard of any restrictions or anything.
Old 10-24-2010, 12:29 AM
NewToDodge's Avatar
I found this on ChargerForumz.com that a guy did 5.7 to 6.1 intake manifold swap. He went through this company: http://www.inertiamotorsports.com/motors.html
The upgrade kit is towards the bottom of the page its $425 for the kit and then you have to supply the manifold and do a couple other things like build a CAI for it, but its very possible.
If I remember correctly I think the guys name was Stu at that company.
There is a picture of the engine with the swap but the file is to large for me to post the picture.. If someone else would like to post it here I have the link.
This is the setup the guy used with the swap:
FRI Ported & Polished 6.1L Manifold
FRI 5.7L Extreme Cylinder Heads
FRI Littleboy Camshaft
Old 10-24-2010, 09:39 AM
Rep:276
yeah thats definitely Stu at Inertia. One of my buddies has his 372 stroker motors which is a 5.7 block based motor and he has the the 6.1 manifold on it. Inertia also makes the manifold swap kit for the 4th gen rams with the 5.7. Definitely one of my next mods.
Old 10-28-2010, 10:09 PM
kool thanks. just looking for little things to do to it.
Old 10-29-2010, 09:51 AM
raceram9's Avatar
raceram9 raceram9 is offline
Vehicle: 07 Flame Red QC
Trim Level: Sport-R/T
Rep:51
raceram9 will become famous soon enough
it will take a lot of work to do it and the 6.1 intake was made for the LXs and you will lose bottom end tq and if you have a 2500 w/HEMI you probably don't want that
2007 RAM QC FLAME RED,20s, 3.92 rear Vararam CAI, Cherrybomb vortex mufflers dumped out in front of rear tires, Superchips Cortex, R/T badges on grill and tailgate custom designed stripes and hood vinyl.....and more to come
