Old 09-08-2011, 09:15 PM
fullmonte60's Avatar
fullmonte60 fullmonte60 is offline
Vehicle: 2011 Ram 1500 Express
Rep:19
fullmonte60 is on a distinguished road
that's for sure.
2011 Ram 1500 Express, Hemi, Black, Jet PCM, Airaid, Magnaflow 10778 & 12198, BT catch can, Bed Armour, Lund Genesis Tri-Fold, Debadged.
Old 09-08-2011, 09:18 PM
Rep:19
are the 6.4 & 6.1 intakes the same?
Old 09-09-2011, 07:50 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:605
There is a visual difference. Not sure regarding spec's or runner lengths etc.
Old 09-09-2011, 10:38 PM
Rep:19
i'll have to eyeball one in the 392 challenger.
Old 10-06-2013, 01:02 AM
RedLineRider RedLineRider is offline
Vehicle: 2013 Dodge Ram
RedLineRider is on a distinguished road
As far as loosing low end torque because of the mixed runners, would porting the internals out and upgrading the TB make for a reason to do this swap? Or is forced induction the only reason you should do this?
Old 10-08-2013, 08:41 PM
blueramtrx's Avatar
blueramtrx blueramtrx is offline
Vehicle: 2008 dodge ram trx4
Trim Level: trx4
Color: patriot blue
blueramtrx is on a distinguished road
I'm looking to modify and improve performance on my truck, hp and torque. i briefly looked at the inertia site and was wondering if this is possible on an 08 5.7 or is this mod strictly for 09+. you guys really seem to know whats going on with this stuff.
anything can be fixed with a little duct tape, WD-40 or cajun ingenuity. Sometimes all 3!
Old 10-08-2013, 09:09 PM
I push the skinny pedal
Rep:3277
I did the swap on my '07. You need to get the machined timing cover and bracket from Inertia Motorsports that will move the alt and A/C comp out to fit the TB. You'll also need to open up the looming on the engine harness and pull the MAP sensor wiring out as it's located at the back of the 6.1L manifold and on the front of the 5.7L manifold. You may or may not have to extend the TB wiring, it was tight on mine, so I decided to solder in 6" extra so it was sitting the way I wanted it to since I had a nitrous TB spacer in it as well. You will also need the port adapter plates from modern muscle to port match the 6.1L manifold to the pre-eagle head intake ports.
Honestly, unless you're planning a bigger stroke, eagle head swap, a supercharger, or a good shot of spray, this isn't a swap for you. It's expensive and the gains are minimal with basic bolt-ons, but the manifold allows for more room in the top end and handles boost/nitrous much better.
Kurtis
Old 10-08-2013, 11:45 PM
Honestly, unless you're planning a bigger stroke, eagle head swap, a supercharger, or a good shot of spray, this isn't a swap for you. It's expensive and the gains are minimal with basic bolt-ons, but the manifold allows for more room in the top end and handles boost/nitrous much better.[/QUOTE]
well I was implying to just keep it N/A. Stroker, Cams,CNC Ported Heads, etc.. But my problem is not sure on how to start parting this out. Can't afford to buy everything at once. Wanted to see if it was worth it to do all this without SC, or Turbo.
Old 10-09-2013, 08:56 PM
Rep:3277
If you're looking for a starting point, then build the rest of the engine first, let this be the last thing you do. If you plan to stay N/A then you'll get more benefit from the variable intake runner length than from the long runners on the 6.1L manifold. You could really go for it and pick up the 6.4L manifold which also has the variable runner lengths but is designed to flow a lot better than the truck's manifold.
Is it worth doing without a major power adder? Not really. Does it look bad ass under the hood? absolutely.
Kurtis
Old 10-09-2013, 10:53 PM
blueramtrx's Avatar
Trim Level: trx4
Color: patriot blue
eventually i wanna do the premium big valve heads and a nice cam, diablo trinity tuner 4.56 gears and 37s . want to end up with a MEAN hemi truck
