Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 10-20-2010, 10:42 AM
maddmattlong maddmattlong is offline
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
maddmattlong is on a distinguished road
Lightbulb no tail lights what went wrong?
i have a 1999 dodge 3500 and all lights work but the tail lights can anyone help me figure this out???
Old 10-20-2010, 10:43 AM
Resident Technician
Rep:1915
What have you checked so far?
Old 10-20-2010, 10:48 AM
bulbs, fuses , and relays when i started only had drivers head light now i have all but taillights
Old 10-20-2010, 11:02 AM
Resident Technician
Rep:1915
Got 12V and a ground at the bulb sockets?
Old 10-20-2010, 11:12 AM
ground is good but no power at the hot wire when i tested it, and cant seem to find a break in the wire, could the switch for the lights in the dash be bad and causing this problem
Old 10-20-2010, 11:22 AM
Resident Technician
Rep:1915
Time to start working backward from the sockets until you find where the power is being lost. If it's the switch, you wouldn't have the front or license plate lamps.
Old 10-20-2010, 11:24 AM
thats what i thought, fun,fun thank you very much for all your help and time
Old 10-20-2010, 11:48 AM
Resident Technician
Rep:1915
Glad to help. Good luck finding the problem.
Old 01-27-2011, 08:51 PM
gwtaz gwtaz is offline
Vehicle: 1998 Dodge Ram 1500
Rep:35
gwtaz is on a distinguished road
I'm having the same problem. Can you explain the process of working backwards. I know how to do things if explained but I have no experience working on electrical problems.
My 1998 Ram 1500 has had problems with no tailights and no interior lights before. I changed the headlight switch and checked/replaced fuses under my knee and in the engine. Kept blowing a fuse under my knee until I dimmed the instrument lights.
Recently, I smelled burning plastic coming from under the dash near the headlight switch and shortly after the police stopped me for no tailights. They haven't worked since.
Checked tail light (running light) bulbs and switched them with the brake lights. Bulbs good. Used a pencil tester to check fuses. Good. Disassembled tailight assm and found frayed wire on drivers side and splice/repaired it. Someone said I'd have to trace the wires from the tail lights to the fuse box, another suggested changing the wiring harness. One mechanic took a quick peek and said power steering fluid or oil was leaking on the wires and could have shorted them.
Suggestions? Thanks.
P.S. - I'm also getting a check engine light to replace the o2 sensor but don't know if it's related.
Old 01-29-2011, 12:59 PM
Rep:35
Bump. I having the same problem.
