no tail lights what went wrong? - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 01-31-2011, 09:43 AM
Resident Technician
Rep:1915
I would say to start by removing the headlight switch and checking the connector plug on the switch itself. The connections can become loose over time and cause a lot of heat and current draw which would blow a fuse. Pay particular attention to the black/yellow wire; this is the one going from the switch to the tail lights. If no problems are found, you'll need to trace thsi wire and look for a short.
Old 02-08-2011, 08:21 PM
mikesram20021500's Avatar
mikesram20021500 mikesram20021500 is offline
Vehicle: 2002 dodge ram 1500 quadcab
Color: marron
mikesram20021500 is on a distinguished road
I had a bad connection in the fuse block. I gust jumped the relay to a hot wire and now when the ignition switch is on I have tail lights
Old 02-08-2011, 11:04 PM
CloneSaw CloneSaw is offline
Vehicle: 2001 Dodge Ram
Trim Level: Sport 4x4
CloneSaw is on a distinguished road
Check the fuse in the fuse box under the hood. I forget what the fuse is called.... I had the same issue last winter when a state trooper alerted i didn't have tail lights.
Old 02-10-2011, 02:02 PM
wbodine's Avatar
wbodine wbodine is offline
Vehicle: 2011 Dodge Ram Outdoorsman
Trim Level: Outdoorsman
Color: Green & Gray
wbodine is on a distinguished road
9 out 10 times its the multifunction switch ( dimmer & turn signal ) thats what it was on mine. About $50-$60 @ Auto-Zone...I was shocked to see it was the same as OEM.
Bodine
Old 02-12-2011, 04:15 PM
gwtaz gwtaz is offline
Vehicle: 1998 Dodge Ram 1500
Rep:35
gwtaz is on a distinguished road
Ok, I'm gonna pull the fuse box today and check. Im also having trouble with my oxygen sensor (rough, lots of gas, plugs fouled with dry black soot, black clouds out the exhaust) and when I checked the 15a (I think) for o2 it wouldn't light up the test light. Pulled fuse and it was good. (Does that mean a short?)
Chasing gremlins and I'm clueless how to catch them.
Old 02-12-2011, 07:35 PM
Rep:35
Went and bought a Haynes book and a digital multimeter. I'm gonna try to figure this mess out.
Old 02-17-2011, 07:51 PM
Rep:35
Thanks to those of you that replied. After looking around I realised the problems were more than i thought and opened a new thread. You can find it here.
http://www.ramforumz.com/showthread.php?t=74692
