Old 10-21-2010, 03:09 AM
thewagon thewagon is offline
Vehicle: 2010 RAM 1500 QC BigHorn
Rep:35
thewagon is on a distinguished road
Arrow Possible to swap RES for an RER unit in 2010 Ram?
I have an opportunity to buy a RER unit (high speed, removed from 2007 Wrangler) and replace my current RES unit in a 2010 Ram.
1) Will it work (plug and play)?
2) Can I transfer current Sirius in RES to RER unit?
3) Other than a nav antenna, will I need anything else?
4) I am expecting to replace front bezel
Thanks mucho in advance!
btw, cost is $650...fair price?
Andrew
Old 10-21-2010, 08:25 AM
Sounds like a good upgrade, Andrew. What I am not sure about is CanBus compatibility, i.e. the low speed vs. high speed issue.
I hope one of our audio gurus, chithead or dodgeman70592, see this and have an answer for ya!
Old 10-21-2010, 08:41 AM
Rep:1885
The swap won't work. The Wrangler uses the CAN-B system (low speed) whereas the '10 Ram uses CAN-IHS (high speed) network.
Old 10-21-2010, 09:18 AM
UN4GTBL's Avatar
UN4GTBL UN4GTBL is offline
Vehicle: 2007 Dodge Caliber
Rep:41
UN4GTBL is on a distinguished road
If you have the part number of the radio, look for it here - http://www.wkjeeps.com/Mygig_parts.htm#PARTS
If you are putting it into a 2009+ Ram 1500 you don't need to change the bezel
2007 Dodge Caliber SXT - 1.8L I4 & 5-Speed Manual
2011 Dodge Grand Caravan SXT Plus - 3.6L V6 & 6-Speed Auto
Wanting a new Ram...
Old 10-21-2010, 10:51 AM
sowardcustoms's Avatar
sowardcustoms sowardcustoms is offline
Vehicle: 2013 Ram R/T
Trim Level: R/T
Color: Gray
Rep:145
sowardcustoms will become famous soon enoughsowardcustoms will become famous soon enough
2007 was the first year for high speed bus used in a few models the wrangler being one of them. I don't see a problem using it I have an older REN mygig I use in my 2010 ram..
Old 10-21-2010, 11:19 AM
Rep:1885
My mistake. I had the wrong vehicle pulled up instead of the Wrangler when I looked up the bus specs. Sowardcustoms is correct.
Old 10-22-2010, 03:36 AM
Rep:35
Thanks for the info everyone. Looks like its going to be an upgrade for me. Just gotta find a NAV antenna and get Sirius switched from my RES unit to the new RER unit.
Old 10-22-2010, 07:18 AM
erik108's Avatar
erik108 erik108 is offline
Vehicle: 2010 slt quad cab
Color: mineral gray
Rep:18
erik108 is on a distinguished road
yes you can just swap out, the ram/& wrangler are both high speed !!
no need to change the bezel, just pop bezel out, 2 screws under the rubber piece on top, if a st or slt, if a sport/ or laramie then u have the middle console, more to it.
then 4 bolts hold radio in, all the connections are the same in the back, & yes you will need the nav antenna ( blue connection) the sirius stays with the radio- However 2007 unless that radio was renewed, then you will have to suscribe again !!!
