Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 10-21-2010, 03:39 AM
96RamC's Avatar
96RamC 96RamC is offline
Vehicle: 1996 Dodge Ram 1500
Trim Level: SLT Laramie
Color: Turqouise / Flat Black
96RamC is on a distinguished road
Default HID Projector headlight problems..
Well guys I don't know if you might know anything but... I have anzo projector halo headlights... and I have put HID's in them earlier this year ... Butttt the beams are aligned, horribly, basically all over the road... I have got them aligned the best that they will go... however when the regular h4 bulbs are in the beams are aligned perfectly... I dont know if the HID's can work with these headlights or not? Has anyone else with these headlights have this problem?
"If you fail the first time, don't quit. Keep trying until you can do it perfectly"
Old 10-21-2010, 06:57 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
I am a little confused at your post.
So you put HIDs in the projectors. or the other one?
HIDs will work best in the projector. The open area is just like stock headlights and spreads it all around. That bulb is also for the high beam, if I am looking at the correct headlights
http://www.topgearautosport.com/part..._with_LED.html
, which you don't really need if you have HIDs.
With HIDs in the projectors you should have a cut off line, see below
Old 10-21-2010, 08:18 AM
I'm confused...I thought projectors would improve the beam pattern.
Old 10-21-2010, 12:58 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
im confused too because thats basically the purpose of projectors to that the beam is not scattered all over the place so i think the op should reword his post and make it more understandable
Old 10-21-2010, 05:05 PM
96RamC's Avatar
Sorry bout that... Basically I have installed HID's into those ANZO Headlights.... This is whats happening, the beam is nothing like the picture... its not as focused... the light is scattered and doesnt provide the brightness regular HIDs would... however when I put the regular halogen bulb back into the projectors... I get a focused bright beam... i'll have to take some pics tonight
Old 10-21-2010, 05:54 PM
Post it up this evening and let us see whats going on .
Old 10-21-2010, 06:00 PM
Rep:713
yea pics would help alot there bud so snap a few when u gets a chance and im sure there will be a few people that can help ya out with your issue
Old 10-22-2010, 12:22 AM
96RamC's Avatar
Well my camera doesnt want to work, so i gotta figure out how to get it to work with night shots... Ill try to get it fixed tonight, or post pics tomm
Old 11-20-2010, 07:59 PM
96RamC's Avatar
Sorry it took me so long guys... been busy as heck lately... Here are some pics
and that is with no light whatsoever around me... When there are streetlights, you cant even see my headlights on the ground
Old 11-21-2010, 01:26 PM
Rep:1930
When you are looking straight at them are you blinded. How far do you have to move to be blinded? You will know when you are in the beam path from the projectors. You may try doing some type of shims to adjust the headlight if necessary.
