Old 10-21-2010, 06:56 AM
sfcgaboy sfcgaboy is offline
Trim Level: TRX4
sfcgaboy is on a distinguished road
Default Rubbing Question
I have a 2010 1500 TRX4 I just ordered a 3 in body and 2.5 inch suspension lift, also ordered XD 797 Spy wheel with 35 x 12.5 Dick Cepek Crushers the rims have a -12 mm offset. Does anyone know whether I should be good as far as rubbing goes or will I need to get some wheel spacers. Thanks for any help I can get.
Old 10-22-2010, 12:40 AM
Rep:1625
You should be fine with that setup. Don't forget the pics when it's done!!
Old 10-22-2010, 11:22 PM
ScatPak07's Avatar
Rep:970
Yea you will have no issues. The 35" tires will fit under there with a 5" lift. Also you have to remember with the TRX model you are already an inch high. When you look into the lift kit you have to make sure it will fit the TRX. So the 5" lift is like a 4" lift on a regular Ram. Just wanted to make sure you get a lift made for the TRX.
Adding those rims will definitely help out with any chance of rubbing. The -12mm will bring them out just right. The stock rims are +20mm offset so you take that to 0 and then -12 you got your 32mm away from where it is now.
Old 10-23-2010, 12:14 AM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
You will be good to go.We want pics when it is done!!!
