Old 10-21-2010, 02:32 PM
barkboxx barkboxx is offline
Color: Black Pearl
barkboxx is on a distinguished road
Default re: Best Tonneau Cover...??
Hi all,
just curious about what the best truck bed covers are out there...I'm looking at a tri-fold style...any recommendations?
thanks,
M
Old 10-21-2010, 02:37 PM
Chili1K's Avatar
Chili1K Chili1K is offline
Trim Level: TRX4
Color: Email: Chili1k@att.net
Rep:1092
Originally Posted by barkboxx View Post
Hi all,
thanks,
M
Love my Bakflip..probably wont try any other if i get a new truck. ill go right back to it.
plenty of posts with pics of it on here..
here was my post
http://ramforumz.com/showthread.php?...ighlight=worse
Old 10-22-2010, 12:51 PM
SvB4EvA's Avatar
SvB4EvA SvB4EvA is offline
Vehicle: 2010 RAM 1500 4x4
Color: Inferno Red
Rep:25
SvB4EvA is on a distinguished road
I am pleased with my BakFlip F1 after the first month of use.
-Steve
Old 10-22-2010, 03:49 PM
Color: Black Pearl
thanks for the input...I think the Bakflip G2 is exactly was I was looking for!!
Old 01-01-2011, 07:35 PM
old hot rod's Avatar
old hot rod old hot rod is offline
Vehicle: 2010 Dodge Ram 1500 4x4
Rep:386
old hot rod is just really niceold hot rod is just really niceold hot rod is just really niceold hot rod is just really nice
Send a message via Yahoo to old hot rod
how easy is the bakflip to use and does it lock?
Hell Bent Steel Leveling kit, K & N filter, Tinted Windows,
Mufflex DOD18M, Mopar Intergrated Trailer Brake,
DiabloSport Predator (U7137) 180 Thermostat, WeatherTech Vent Visors
DiabloSport Catch Can (C-1040)
Old 01-01-2011, 07:39 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
After months of reading on here and research on the net myself, I ordered a Bak-flip G2 and am waiting for it to arrive.
Based on what I found out it gives the best of all worlds.
1. Security: If the tailgate is locked, the cover can't be opened without a pri-bar.
2. Each panel latches in place so you can open it part way and still drive.
3. Once one panel is folded back onto another, you can stand on it with no problems.
4. It can be opened all the way to allow for access to the whole bed or removed in minutes if needed.
Brian:
Old 01-01-2011, 07:45 PM
JRI JRI is offline
Vehicle: 2010 Ram Crew Cab
Rep:14
JRI is on a distinguished road
Real easy to use and a locking tailgate it required. Just check their web site or go on youtube and there are loads of video showing operation. I've had mine for 8 months and have no regrets.
Old 01-01-2011, 08:30 PM
05Train's Avatar
05Train 05Train is offline
Vehicle: 2010 Ram
Trim Level: Sport Quad Cab
Rep:24
05Train is on a distinguished road
I've had a BakFlip F1 since August. I got the F1 rather than the G2, because I didn't want to worry about it denting, I wanted it to be as light as possible, and the warranty's longer. The BakFlip is, as far as I'm concerned, the best cover available if you regularly haul things in your bed that are taller than the sides of the bed.
When not hauling, it looks fantastic. It's about as watertight as can be expected, truthfully I think what water gets in is coming from the tailgate and all the various holes in the bed. If you have a drop-in bedliner, this won't be an issue.
When hauling, there are a couple of serious drawbacks. Let's say you're hauling a headboard for a king-sized bed. You can't shove it against the front of the bed, as the folded cover is there. You also can't lean it against the sides of the bed, as the support arms for the cover are there.
Let's say you're hauling 20 sheets of plywood with the tailgate up. Rather than just loading and going like you would normally, you have to strap the load down to keep it from shifting, otherwise you'll crush the side rails for the cover. You also need to watch your drain tubes if you run them to the holes on the lower sides of the bed.
Someone (Root Beer, I think) mentioned he was going to run the tubes out the stake pockets, however that wouldn't work for me, as the angle was to tight and there wasn't enough fall in order for the cover to drain. YMMV.
Now with all that said, I don't think there's a better cover out there for anyone who regularly uses the bed of their truck.
Old 01-02-2011, 01:23 AM
jdlatil's Avatar
jdlatil jdlatil is offline
Vehicle: 2010 Dodge Ram Crew Cab
jdlatil is on a distinguished road
F1 here too, got the Bak box also, it kind of small for a tool box but out to the way and nothing rolling around in the bed.
2010 Crew Cab Bighorn Hemi, F1, Bedrug, SC 93 tune, 3.92 & Detroit Locker, K&N. 14.37 @ 96 mph
Old 01-02-2011, 11:09 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
whats the difference in f1 and g2
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
