Old 10-22-2010, 04:48 PM
WesGPS's Avatar
WesGPS WesGPS is offline
Vehicle: 2005 Dodge Ram HD 4x4 S. Box
Rep:68
WesGPS will become famous soon enough
Default Battery Isolator
I have recently purchased a Lance Truck Camper and will have to install a six way plug.
I picked up the plug / harness from the same dealer I purchased my camper from.
From reading a camper forum and talking around a little bit with a Gearhead or two that I know, it seems to me a Battery Isolator would be a good thing to have. As I understand it, an isolator will keep the main truck battery from being pulled down in the event the battery in the camper drops down so far that it needs juice from the main main battery - that way one stands less of a chance of getting stranded in the backwoods. Yet - the isolator does allow enough juice to flow through to charge the camper battery.
I would appreciate any recommendations and comments.
Here is a link to one I surfed up that I am thinking about picking up from the local Northern Tool store. The model number is B1201B2E. It is the only one on the Northern Tool site. If you care to check it out just click here: Northern Tool - and type "battery isolator" in the search box.
I will also bounce my question off of the local Lance Dealer but I want to hear from folks with real World on-the-road experience with battery Isolators.
Thanks, Wes
2005 Dodge Quad Cab Heavy Duty 4X4 5.7L Hemi.
Air Lift Remotely Controlled Air Bags.
Hellwig Rear Anti Sway Bar.
Viair Onboard Air System.
Old 10-22-2010, 06:00 PM
Rep:2597
on my last truck i had to run 2 batteries, both under the hood, from the time that i put the 2nd battery in, it messed with some systems in the truck, i ended up having to put a isolator under the hood, problems were solved,
seems that i was getting a electrical spike when i shut off the key, it was burning out some electrical components, the isolator stopped that from happening.
I never had an issue with batteries going dead either, but, i didn't have a camper.
another solution for people that tend to run down their battery, you might want to think about getting a solar battery charger, some just lay on your dash board & plug into your cigarette lighter, the sun going through your windshield heats up the solar panels, the electricity then flows through your cigarette lighter & helps to keep the battery charged up
http://www.12voltsolarpanels.net/sol...ttery-chargers
Old 04-02-2011, 01:43 PM
astroman54's Avatar
astroman54 astroman54 is offline
Rep:52
astroman54 will become famous soon enough
One word of caution with the solar battery chargers. Plug them into an outlet that is powered all the time and it will charge the battery. If you plug it into one which turns off with the key, then it won't charge.
Andy
Andy
2009 Dodge Ram 1500 Sport Deep Water Blue Crew Cab Hemi 4x4
