Old 10-22-2010, 06:05 PM
96DodgeRam1500's Avatar
96DodgeRam1500 96DodgeRam1500 is offline
Vehicle: 1998 Dodge 2500 4x4 Sport
96DodgeRam1500 is on a distinguished road
Default Smelling antifreeze coming through the vents
Ive noticed here lately that i smell what seems to be antifreeze coming through the vents inside the truck.. it happens more whenever i get on it. Not sure what could be causing the smell and I dont think its a normal thing, but i could be wrong.
1998 Dodge Ram 2500 Sport 4x4. 360 all stock. Leveling kit with 315s.
Old 10-22-2010, 06:21 PM
Definitely not normal so I suspect a leak or a heater core giving up.
Old 10-22-2010, 06:37 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Any steam out of the vents, or wet carpet? Are you losing coolant?
Old 10-22-2010, 07:52 PM
Rep:1909
Your heater core is leaking.
Old 10-23-2010, 02:07 AM
No, I dont have any steam coming out of the vents, that ive seen, and Im not losing coolant. The reservoir is probably a little under max level and I havent put any coolant in it since i bought it from my dad a year ago.. my carpet does get wet on the passenger side. And i figured the heater core but my dad checked it a while back and he said he couldnt find any cracks, leak traces, or anything. Tomorrow Im going to check the heater core myself. If its leaking then there should be white water mark traces left, right? Thanks for the input. Let me know if yall come up with any other things it could be.
Old 10-23-2010, 02:27 AM
arnoldziffel's Avatar
arnoldziffel arnoldziffel is offline
Vehicle: 2006 Dodge Ram 1500
Color: inferno red pearlcoat
Rep:18
arnoldziffel is on a distinguished road
sounds like a heater core. i had a chevy monza that had the same symptoms. you could try bypassing it and see if it stops smelling.
Old 10-23-2010, 05:05 AM
bogies87's Avatar
bogies87 bogies87 is offline
bogies87 is on a distinguished road
+1 on the heater core
Old 10-23-2010, 07:55 PM
thirdmouse's Avatar
thirdmouse thirdmouse is offline
Vehicle: 1994 Ram 1500
Color: red
Rep:25
thirdmouse is on a distinguished road
I just changed my heater core today. You're in for some fun.
This truck is brought to you today by the letter V and the number 8.
Old 10-24-2010, 12:20 PM
It's a bad heater core . Nothing uncommon for this generation ram . Make sure you change out your coolant also . I firmly believe the coolant that was used from the factory wasn't of the best quality . I had to do mine at 50,000 miles . My coolant was still a nice pretty green color . I performed a electrical test on the coolant and it showed the coolant as probably being the reason for the core failure . After the new core was installed , I did a coolant system service while I was in there then performed that test again and was amazed at the results . Since then no more problems with core failure . Even the replacement core came with directions on how to test the coolant . So just don't assume that with the coolant being it's factory color that it's ok .
Old 10-24-2010, 07:25 PM
Thanks for the input.. Yeah Im probably gona go ahead and change out the heater core and flush the system then throw some fresh coolant in. The coolant got changed about 6 months before i got the truck because the water pump had went out.. but i am gona go ahead and get a new one just to be on the safe side.
