Old 03-09-2011, 10:40 PM
sullivan's Avatar
sullivan sullivan is offline
Vehicle: 2006 Dodge Ram Sport 5.7
Rep:202
sullivan has a spectacular aura aboutsullivan has a spectacular aura aboutsullivan has a spectacular aura about
Default Bilsteins on the way
My bilstein order finally went through and comes in next Tuesday.
I looked under my truck today, and the bushings where the shocks and bolt meet are kind of dry rotted and old. I would like to get new ones but can't figure out where to get them.
Also, will I need any special tools? Such as a spring compressor? I am not exactly sure how to install them, but I have a friend who is going to give some verbal advice.
06' Sport - 3.92 Gears - Superchips - Bilstein Shocks - HellWig Anti-Sway Bar - Cooper Zeon LTZ - Viper Alarm & Remote Start - Halo Projector Lights - 5k HID Lows & Fogs - Custom Emblems - Magnaflow - CAI
Old 03-10-2011, 02:34 PM
Muddbog's Avatar
Muddbog Muddbog is offline
Vehicle: 2007 Dodge Mega Cab 4x4
Color: 2 Tone Blue/Silver
Rep:20
Muddbog is on a distinguished road
Send a message via Yahoo to Muddbog
You should be able to install the front shock without jacking up the truck. I just installed Level-Rite shocks on my MC but yours may be different. Old shocks pull right out through the top remove 3 nuts from top of strut tower, remove lower bolt, pull through top then remove the bracket from the old shock. insert new shock without bracket, install lower bolt, install bushings on top of new shock, install bracket, install 3 nuts on top of strut tower and you are done. should take no more than 1 hour.
2007 Dodge Mega Cab 4x4 5.7 Hemi
Old 03-10-2011, 04:30 PM
sullivan's Avatar
Rep:202
Sweet thanks. What about new bushings?
And I am gona pick up a spring compressor rental before I start.
Old 03-10-2011, 08:47 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
congrats on the purchase bud im hopefully ordering a set real soon aswell
Old 03-11-2011, 07:58 PM
Muddbog's Avatar
Rep:20
bushings came with mine but I can't say for sure on yours.
Old 03-11-2011, 08:01 PM
You should get new bushings already in place on the new shocks.
Use some penetrant at each bolt and nut, letting it sit for a while, before you try taking them off. It may spare you snapping a bolt.
Old 03-11-2011, 08:43 PM
sullivan's Avatar
Rep:202
Thanks, the previous owner installed ranchos and the bushings look old as hell now. Wanted to make sure.
bilsteins........ seabass Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 03-07-2011 09:15 PM
Bilsteins are junk belle Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 03-07-2011 09:04 PM
Any 4th Gen Vibration with 2" level kit or Bilsteins? FormerGorilla Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 02-23-2011 05:12 AM
Does anyone have the adjustable Bilsteins yet? hpc3 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 20 12-21-2010 05:21 PM
2007 1500 2WD 1500 Sport/want Bilsteins and coil spacers/rear blocks DanoHB Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 03-21-2010 10:59 PM
