Injector Problem! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 10-23-2010, 11:46 PM
pokeyjoe pokeyjoe is offline
Vehicle: 2003
Color: BLACK
pokeyjoe is on a distinguished road
Default Injector Problem!
ok my 5.9 Cummins has left me stranded! got it to my diesel guy who said the computer said it was the cam sensor. Sensor replaced no change. The truck is loading up on fuel and the diesel guy says that one of the injectors is dumping to much fuel and not letting the fuel rail pressure build up. The diesel guy says he needs to MAKE some kind of plug to plug up one injector at a time to determine the one that is staying open. DOES ANYONE KNOW WHERE TO GET A PLUG or WHATEVER I need to do this? PLEASE HELP I NEED MY TRUCK BACK ON THE ROAD.....
Stephen Duncan 2003 Dodge Ram 3500
5.9 Cummins Turbo Diesel
Old 10-24-2010, 09:18 AM
iRESQu iRESQu is offline
Rep:2217
This guy....is he a Dodge Certified Tech (not knocking him, just asking)? The reason I ask is because he has advised you once about a component and it didn't appear to be your problem. Let's start from the top, are you throwing codes? Tell us exactly what the truck is doing, when is it doing it and how often?
Old 10-24-2010, 10:57 AM
Resident Technician
Rep:1915
Never heard of any such plug. I'm guessing he can't get his hands on the correct tool to flow test the fuel system so he's gonna try to rig up something.
Old 10-24-2010, 12:08 PM
Is it smokin black real bad ?
Old 10-24-2010, 02:22 PM
Vehicle: 2003
Color: BLACK
ok so here is what my truck is doing. IF it will start white smoke POURS out the tailpipe along with fuel. Then IF it will idle at all as soon as you touch the gas pedal it cuts out. My diesel guy said the only code was for the cam sensor. That has been replaced. To me I think that one of the injectors is dumping to much fuel out and flooding out the engine. He wants to TRY and plug off one injector at a time to determine the bad one. ANY IDEAS GUYS?
Old 10-24-2010, 09:02 PM
I'm no diesel guy , but I don't think one bad injector could flood out the engine .
Old 10-27-2010, 08:47 PM
Scotty1500 Scotty1500 is offline
Vehicle: 2000 dodge ram 1500
Color: red
Scotty1500 is on a distinguished road
im no diesel kid either, but white smoke is oil being burned or you have a head gasket blown, check your head gaskets and look for any leaks
Old 10-28-2010, 09:49 AM
Vehicle: 2003
Color: BLACK
OK it WAS an injector #5 stuck wide open. Put a new one in a it runs perfect.
