Old 10-24-2010, 12:30 PM
ohmega07's Avatar
ohmega07 ohmega07 is offline
Vehicle: 07 Mega Cab
Trim Level: laramie
Rep:183
ohmega07 has a spectacular aura aboutohmega07 has a spectacular aura about
Default superchips Torque Mngment Tuning
Anyone come up with some good starting points for using the new superchips program for torqu management?
The post "this will make you do a burnout" - kind of faded out and didnt get any numbers.
i went in and played with mine, removed all torque management and tweaked the shift points and max rpm's. Truck accelerates very nicely now, seems like a more solid acceleration, havent been able to do the burn out, but then again i have 37x13.5x18 tires so maybe thats just not gonna happen for me unless its raining!
But since i am no pro when it comes to the numbers, still wanting to hear from others about how they programmed thiers?
thanks
"If I was worried about gas mileage, I would have bought a Kia"
Old 10-24-2010, 01:09 PM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 Dodge Ram SRT10 RC 6spd
Trim Level: SRT10 RC
Color: Brilliant black
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
I have all mine set at 8% across the board, I had read that zero you can actually loose performance.
Traded in[SIGPIC]2004 SRT10 RC in black, with 500+HP, B&G Stage2 PCM, K&N drop in, JMB Catless mids, JTSVP Gen1 shifter, all synthetic fluids, lots of underhood billet with a Snakeskin radiator cover from JTSHydro, LED tails, BedRug, colormatched tonneau!!!!!!!! Upgraded!!!!!!!!
Old 10-24-2010, 04:11 PM
ohmega07's Avatar
Trim Level: laramie
Rep:183
really? why would you lose power with 0% torque management? I figured that with 0 management that it would just run like it would without the restrictions of a torque management program? Im new to this kind of programming so if you got info, by all means let me here it!
thanks!
Old 10-24-2010, 07:00 PM
05ram's Avatar
Rep:145
the info is not here but i will get it for you, it came from one of the beta testers for this program, you need a little tq man for better shifts.
Old 10-24-2010, 07:06 PM
ohmega07's Avatar
Trim Level: laramie
Rep:183
ok cool, just want to make sure i am using the program properly to get the most benefit from it.
thanks
Old 10-24-2010, 09:29 PM
05ram's Avatar
Rep:145
i'm still looking.
Old 10-25-2010, 08:54 PM
05ram's Avatar
Rep:145
During our many months of testing we found that a little bit of TM is more responsive than no TM. Think about it in the sense of friction, if you are to apply torque to the trans, the higher the friction. If you reduce it a little the lower the friction, and this is an non-linear reduction. Too much torque and the truck will lag it's shift. Personally I would leave some TM in all of the shifts. The shifts will complete quicker with some load reduction.
there it is
