Chassis Lube - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-15-2010, 03:41 PM
icephreaq's Avatar
icephreaq icephreaq is offline
Vehicle: 2015 Crew Cab 4x4
Color: Blue Streak
Rep:99
icephreaq will become famous soon enough
Default Chassis Lube
Not sure if this is the right place to post this question but I figured the suspension guys would know. My driver side rear leaf springs have developed a really obnoxious squeak where they bolt on to the frame. What kind of lube can I use and how should it be applied to get rid of this annoying problem?
2015 Big Horn :5" Ionic Oval Step Tubes, Line-X Platinum Liner, DeeZee Tailgate Assist, CabinFilter Mod w/ K&N filter.
Retired :2008 4.7L The truck that brought me to the Z.
Old 11-16-2010, 12:01 PM
Rep:1915
Try whatever you can find that's safe to use on rubber and plastic and spray it into the bushings and between the leafs and see if that helps.
Old 11-16-2010, 07:00 PM
05ramguy's Avatar
05ramguy 05ramguy is offline
Vehicle: 2005 Dodge Ram
05ramguy is on a distinguished road
i have found that white lithium grease in the spray can has worked really well for me on my old truck
2005 Ram Reg. Cab 5.7l hemi, True Flow intake, Flowmaster Exhaust, debadged
Old 11-17-2010, 08:08 PM
icephreaq's Avatar
Color: Blue Streak
Rep:99
Thanks for the input guys! After digging through all of the various lubricants at AutoZone, I went with good ole WD40. Just about everything else was marked unsafe for rubber and plastic. The squeak is gone, we'll see how long it lasts ;-)
Old 11-17-2010, 09:14 PM
Rep:2962
the only problem with WD-40 is that it attracts dirt
some people use.. lithium radical grease or black lead grease
any lube that reads that it is a automotive lube & marked as a PFPE lube is the best, i think even the dealership carries it, but, i don't know what they call it
here are some brand named PFPE lubes
http://www.google.com/search?q=pfpe+...=shop%3A1&aq=f
Old 11-18-2010, 03:13 PM
icephreaq's Avatar
Color: Blue Streak
Rep:99
Looks like I'll have to give that a shot. The WD40 didn't even last 24 hours in the damp conditions we currently have in Memphis right now :-(
