Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 10-26-2010, 09:00 PM
mjshealy mjshealy is offline
mjshealy is on a distinguished road
Well ive got positive pressure, no vacuum. So it isn't the plenum gasket. just took back the TPS sensor again and will try this new one and post on how it goes.
Old 10-26-2010, 09:39 PM
coonhound130 coonhound130 is offline
coonhound130 is on a distinguished road
How do you test the MAP sensor ????
Old 10-26-2010, 11:20 PM
well, replaced the tps sensor again and same problem exists. Upon driving it, i did figure something else out. It's not position on the gas pedal that does it. If i barely put the gas on, and ever-so-slowly add to the pedal, it's fine. And it doesn't show the symptoms when i floor it because its in the higher RPMs. If the engine is over 2300 RPMs, it doesnt have a problem... so if i drive with OD off it's OK, but i still have red lights, so that's an issue. just thought you guys should know it's only under about 2300 RPMs. Sounds like a vacuum leak to me, or maybe the IAC? If it's in neutral, at idle, the IAC tapers up slowly to wide open when it starts messing up. That leads me to believe it's a fuel problem... but pressure is steady... so i'm very confused.
Old 10-26-2010, 11:21 PM
I really hope i can get some help before i end up dropping an A-bomb on the damn thing. I'm so frustrated right now.
Old 10-26-2010, 11:38 PM
That is exactlty what mine done , even the over drive off made it better . I am telling you the mechanic said my crank sensor was loose , they removed it cleaned and reinstalled it and it is better now . I told you this already , save yourself the headacche and try this as it fixed mine that had the EXACT same symptoms as yours ..
Old 10-28-2010, 07:56 AM
alright man... ill try the crank sensor tonight. Ill post up and let you know how it goes. I ran a vacuum test yesterday and it stayed solid at 22 inches of mercury... so there's no leak. I even tried it at various connectors all the way down the line. When it kicks down and runs like crap it drops to 16 inches of mercury... but that's most likely because it's idling at 300. Will post up later.
Old 10-28-2010, 09:56 AM
Resident Technician
Rep:1909
The best way to test a MAP sensor is with a lab scope but even many shops doen't have one. If you have a scan tool that displays data, start by checking the baro reading with the engine off. It should be around 28-29 in. hg. unless you live at high altitude. Attach a vacuum gauge to a manifold source and start the engine. The vacuum gauge shoul read within 1" of what the sensor is showing in the scan tool display. Any big deviation from these numbers indicates a bad sensor. Also the sensor can still be bad and this test won't always catch it because the scan tool just can't display info or dropouts like a lab scope.
