Old 10-25-2010, 02:03 PM
09 TRX AGGIE 09 TRX AGGIE is offline
Vehicle: 2013 1500 Black Express 4x4
Rep:130
09 TRX AGGIE will become famous soon enough09 TRX AGGIE will become famous soon enough
Default Under Hood "push-button" sensor question
i have a 2009 dodge ram 1500. i want to install some behind the grille lights and i purchased the hella black magic 500's. well, come to find out they are a little bigger than i expected and they wont quite fit where it seems like most people put them on the rad support. so then i determined i could fabricate a bracket to raise them and they would be in the upper half of the grille. but then i ran into this thing pictured. it is some sort of push buttom sensor that is depressed when the hood is closed (picture 2). it is located on the drivers half and has a prong attached to the actual hood. anybody know what it is? i didnt have any warning light or msg on the dashboard with hood open or closed when playing with it.
i just wonder if i can remove from its current location and just have it manually depressed at all times....
thanks for any feedback
Old 10-25-2010, 02:09 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Alarm switch if the hood gets opened? Hood light?
Brian:
Old 10-25-2010, 03:07 PM
Rep:1877
It's called the hood ajar switch. If you have remote start, it has to be in place and functional.
Old 10-25-2010, 05:53 PM
Rep:130
thanks randy.
yes i have remote start, so i guess i'm leaving it there
Old 10-25-2010, 06:22 PM
lancelanz's Avatar
lancelanz lancelanz is offline
Vehicle: 2009 Ram 1500 Crewcab 2wd
Trim Level: SLT/Big Horn
Color: Austin Tan Pearlcoat
Rep:65
lancelanz will become famous soon enough
Send a message via Yahoo to lancelanz
You could move it to a position where it will still be depressed with the hood closed. As long as it is depressed the remote start will still work
09 Ram 1500 Big Horn Crew Cab Hemi Spray in bedliner,Flowmaster Original 40,6000k HID lows/fogs
