Old 10-25-2010, 07:47 PM
jason3506's Avatar
jason3506 jason3506 is offline
Vehicle: 1999 ram 1500
Color: silver
Rep:19
jason3506 is on a distinguished road
Question which to choose?
I love my 99 ram. was thinking about the best way to add H.P, tear the engine down and put a more agressive cam and have the heads done, or buy the programmer or a chip. Any thoughts?
Jason
Old 10-27-2010, 01:53 AM
97ram1500 97ram1500 is offline
Vehicle: 2014 Dodge Ram
97ram1500 is on a distinguished road
Well personally if your going to tear the engine down to just do a cam and heads i would spend the extra time and money and build everything up. However a programmer would be probably cheaper then tearing it down but without any additional mods a programmer won't do super much for HP
Old 10-27-2010, 09:50 PM
jason3506's Avatar
Color: silver
Rep:19
I do have a few mods installed. mostly exhaust. i'm working on some tb mods to help it breath a little better. then the chip or heads.
Jason
Old 10-27-2010, 10:18 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Whether you tear it down or not, it will benefit from a CAI, opened up exhaust (headers and all the way back) and a programmer/tuner.
Brian:
Old 10-29-2010, 06:58 AM
jason3506's Avatar
Color: silver
Rep:19
Talking
well i do have headers and a high flow cat back system so flow should not be a problem. the delima i am haveing is i am looking for about 300 to 350 HP. i am not sure i can get that from the programmer. do you have any experience with them and how much did it help?
Jason
Old 10-29-2010, 08:20 AM
Sounds like if you are gonna tear it down, which is what I'd do, then go with a bore and stroke, increasing cubic inches.
You won't get that kind of gain from a programmer. It will require you build an engine.
A buddy of mine out here got a used 5.9L from a wrecked truck and had a local firm build him a 408 forged stroker for it. They did a dyno and he was getting about 390 at the crank with a mildly aggressive cam and MOPAR heads with some porting and polishing, a FAST fuel injection system and a B&G custom PCM flash. The truck runs great!
Old 10-29-2010, 12:47 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
That'd be what I'd do. At least check your bores for wear, and if you can't spend for the stroker, at least bore your your block .030 or .040. IMO ring seal is crucial to power with these engines.
Old 10-29-2010, 01:07 PM
jpaul51's Avatar
jpaul51 jpaul51 is offline
Vehicle: 2009 Ram 2500 Megacab
Rep:167
jpaul51 has a spectacular aura aboutjpaul51 has a spectacular aura about
Cam and heads if you have the money!
2007 Ram 1500 QC - SOLD and bought a 2009 4x4 Megacab 2500 with 6.7 Cummins. Full Sinister EGR/Throttle Valve/dpf deletes, 4" Turbo back exhaust, Banks cold air intake, EFI Live tuning by Anarchy Diesel running 100hp Street tune. Peragon bed cover.
Old 10-30-2010, 06:31 PM
jason3506's Avatar
Color: silver
Rep:19
well i was hopeing to get out with as little time lost as possible. Having said that i dont think i should tear it down without aleast having the block cleaned and checked. may need to get a rental for a little while.
Jason
Old 10-30-2010, 06:50 PM
Color: RootBeer
Rep:1287
Problem with doing just the top end on an older motor is it is very common for the increased compression to blow out the bottom end.
Brian:
