Old 10-25-2010, 08:48 PM
srtsir's Avatar
srtsir srtsir is offline
Vehicle: 2004 Dodge Ram
Rep:198
srtsir has a spectacular aura aboutsrtsir has a spectacular aura about
Default AIR RAM power wire
has anyone done this to their hemi and does it acctually work????Sounds interesting I wonder if it works with my diablo 93 tune???
http://www.airram.com/product.php?ca...6&productid=21
5.7 HEMI, DIABLO, K&N INTAKE, MBRP CATBACK, 4.56 MOTIVE, DMH E-CUTOUTS, 22X10 SRT-10 RIMS (BLACK), 315/45/22 COOPER ZEON XST'S, 2/4.5 MCGAUGHYS DROP KIT, 6K HID'S FOGS & HEADS, RECON L.E.D TAILGATE STRIP, EFX ROLLPAN, TRUXEDO LO-PRO, HORNBLASTERS 156DB TRAIN HORN, HONEYCOMB GRILLE....
Old 10-25-2010, 08:58 PM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 VW .:R32, 3.2l AWD V6
Trim Level: .:R
Color: UGM
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
it works, they dyno tested it to produce 8-10 hp at wot. i have had one for a year or so and love it, it adds a little more fuel at wot, go for it. it would work great with all of your mods
2008 VW .:R32, 3.2l, AWD, V6, #2952/5000
Old 10-25-2010, 09:05 PM
srtsir's Avatar
Rep:198
hey for 39 dollars it seems better perf.. than diablo
Old 10-25-2010, 10:38 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
It just says that it tricks the computer into thinking the IATs are 20 degrees cooler then they really are causing a bump in timing. If you have a DSP save your money and do it yourself by advancing your timing 1 degree. That will probably be about 8hp. But realize that the canned DSP tunes are already advancing your timing when compared to stock. Unless you also add fuel to your tune all you are doing is increasing your risk of detonation b/c the computer is tricked into thinking the IATs are lower....or if the knock sensors sense knock they will pull timing and reduce your power anyway.
Another thing it states is that the stock O2s will keep the a/f "nailed" at 14.75:1. This isn't true because the stock O2 sensors are narrow band which typically operate between a 0-1 volt signal. Narrow band O2s are less accurate and only measure if you are running rich or lean when compared to the 14.7:1 it wants. And oh BTW none of this applies under WOT b/c you want a richer a/f.
A wide band on the other hand operates in the 0-5 volt range and measures your a/f constantly down to the tenth. It can make adjustments to your short and long term trims much more accurately and quickly.
Here is a link if you care to read more. There is a lot out there if you search wide vs narrow band O2s.
http://www.wmswideband.com/tech.htm
IMHO it is a big waste of money. If it works for 05RAM then that's great but his profile also doesn't say if the truck is DSP tuned or stock.
Old 10-25-2010, 10:48 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
there a link on a diy for power wire if you want i can post it here.
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 10-25-2010, 10:50 PM
Blackzilla's Avatar
Vehicle: 2009 Reg Cab S/B 4X4
Trim Level: Sport/SLT
Color: Black Pearl
Rep:199
had this on my 05 Daytona Ram.......
Old 10-26-2010, 02:12 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
need to datalog a/f to see if you need a pw or not... it tends to add more fuel at any given rpm range. In a stock and very lightly modded setup this works well, but in higher modded setups we tend to lean out the fuel delivery..
Old 10-28-2013, 03:53 PM
Jonny klassen Jonny klassen is offline
Vehicle: 2003 dodge1500
Trim Level: Sle
Jonny klassen is on a distinguished road
What do you have to buy to do the power wire mod
Old 10-28-2013, 05:32 PM
TheSatinPumpkin's Avatar
Color: Satin Orange
Rep:627
happy 3 year anniversary to you thread.
