Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Fuel System
Fuel System All Fuel Discussions. MPG - Mileage - Fuel System Maintenance including Air Filter Replacement.
Old 10-26-2010, 02:16 PM
Brute's Avatar
Brute Brute is offline
Vehicle: 2009 Dodge Ram 1500
Rep:56
Brute will become famous soon enough
Default Spark Plugs for an '09 4.7 liter?
I am due to change the upper bank of spark plugs in my '09 Ram with the 4.7 liter. I have checked out the local auto parts stores and dont really trust them. Something is up with selection, they seem to list hundreds of spark plugs for my engine and I know that isn't right.
So, What kind of spark plugs do you guy run? Or what kind have you put in your 4.7? My local dealer says he only has 7 in stock but will order more in. Said he didn't realize they were that low.
Old 10-26-2010, 02:23 PM
Rep:1885
You can use either the Bosch FR8TE2 or the FR8T1332 which is what's used in the bottom row.
Old 10-26-2010, 02:26 PM
Brute's Avatar
Rep:56
Would the FR8T1332 be an upgrade? Would I gain anything by using them? Or is it just easier to keep them all the same?
Old 10-26-2010, 02:28 PM
Rep:1885
The bottom row plugs are iridium. They went that route because they're a bitch to change. If you want to use iridium up top, these are the ones to go with.
Old 10-26-2010, 02:39 PM
Brute's Avatar
Rep:56
Can you only get them at the dealership?
Old 10-26-2010, 03:30 PM
Rep:1885
I wouldn't think so but I haven't searched the parts stores for them.
Old 02-27-2011, 04:17 AM
Gene K Gene K is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Gene K is on a distinguished road
(I know its old) Just adding this in case someone wanted to get these plugs from another source.
Intake (upper) = Bosch Super Plus (this is the correct Nickel Yttrium plug) FR8LCX( stock # 7962 )
Exhaust (lower) = Bosch PlatinumIR Fusion (this is the correct Iridium plug) FGR8LQI0 ( stock # 4508 )
Gene
