Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Place your Ad Here!
Old 10-26-2010, 02:29 PM
RichieUnuk RichieUnuk is offline
RichieUnuk is on a distinguished road
Default 04 IPM wiring diagram
Does anyone have a wiring diagram for the fuse box/relay centre itself? I think my ground is corroded inside the integrated power module. Can I run a ground to a relay without taking the IPM apart?
Old 10-26-2010, 02:34 PM
Resident Technician
Rep:1915
There are about 50 different diagrams for the IPM. You'll need to be more specific about which circuits are giving a problem.
Old 10-27-2010, 09:31 AM
I have no park lights......the relay and fuses are good. they work when I jumper the terminals. I think the ground to the relay is an open circuit. I want to jumper a ground to another terminal if possible. I would like the wiring diagram for the ground circuit through the IPM /fuse box.Thanks for any help you can offer.
Old 10-27-2010, 09:32 AM
Resident Technician
Rep:1915
Old 10-27-2010, 09:33 AM
Resident Technician
Rep:1915
I doubt you have a corrosion problem. Chances are the FCM is bad and if it is, you may see more electrical gremlins pop up in the future.
Old 03-14-2011, 09:06 PM
senake2 senake2 is offline
Vehicle: 2005 dodge ram 2500
Trim Level: custom
Color: maroon
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
senake2 is on a distinguished road
Originally Posted by RamTech View Post
Hi iam having a problem with clutter of my 2005 ram 2500 , nothing is working ,i checked all the fuses ,looks ok, i might think it could be the IPM, but cant locate it, does anybody know where is it? thanks for the reply
Old 03-15-2011, 01:25 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Under the hood, drivers side, about 1/2 way to the front. It's the thing with the fuses on top.
brad
Interested in one of my mods?
Old 12-17-2011, 12:38 PM
Bruce Benj Bruce Benj is offline
Vehicle: Dodge 2006 ram
Trim Level: Night Rider
Bruce Benj is on a distinguished road
Unhappy No Parking Lights
I have the same issue I did try to hard wire them but they wood not turn off. So I am just going to replace the TIMP. Sry I am not much help but you may cause more problems thenit is worth.
fuse box relay, integrated power module
