Old 10-26-2010, 08:31 PM
blackout's Avatar
blackout blackout is offline
Rep:16
blackout is on a distinguished road
Exclamation Still no A/C!!
well i've been lurking around finding solutions for my A/C problem. at first it would on wok in the high fan setting(sometimes). so I checked the Fuses and relays under the hood, then after some research i found that the Resistor under the glove box could be the issue. I replaced it now the different fan settings work but only when it wants to. It has its own brain or something, its turns on when it want to, when the knob is at a fan setting. As i drive i can feel air through the ducts but not at the fan speed, the faster i go the more air comes in, and i can change it if i want it to the floor or at the top, or defrost.
Any clues, all relays and fuses are good, the blower motor works( tested it by direct current), and the resistor is new just replaced. Still no air comes out.
Old 10-26-2010, 08:39 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
If I understand it correctly you cannot set the fan speed regardless of A/C or heat or vent, right?
You've checked fuses and relays and replaced the resistor for the motor. You've tested the motor with direct current.
That leaves only one thing in my mind, the switch itself.
Brian:
Old 10-26-2010, 09:08 PM
blackout's Avatar
Rep:16
once it decides to turn on i can change the blower speed, but only when it decides to turn on. i just keep it in high an pray it would turn on. But i guess it might be time for a new or used switch.
Old 10-26-2010, 09:11 PM
Color: RootBeer
Rep:1287
Well, if the motor works fine when under direct power it seems to me the only option is the switch or a short someplace.
If you can take the switch out, try connecting it between the motor and a direct power source. Then operate the switch and see what happens. I recommend at least putting a fusible link in-line for protection.
Brian:
Old 01-14-2011, 05:33 PM
blackout's Avatar
Rep:16
Alright I tried everything an still no A/C, but just a week a go I had to use my E-Brake and as i lifted the lever to disengage the brake the blower kicked on. So what seems to work for me is slamming the E-Brake release lever every time the fan doesn't want not start. It might be some relay or loose wire under the steering/pedal area but i'm good as is. I thought i might share my Experience to others that might be scratching their heads trying to make their a/c work.
Old 01-14-2011, 05:47 PM
SnowChief SnowChief is offline
Vehicle: Ram 2500 SLT Quad Cab
Rep:147
SnowChief will become famous soon enoughSnowChief will become famous soon enough
I am sorry to hear your AC does not work and even more sorry that I cannot offer any technical suggestions.
I would be happy, however, to trade you some artic air (single digits farenheit right now) for hopefully warmer air where you live!!!!!!
Old 01-14-2011, 06:07 PM
blackout's Avatar
Rep:16
haha!! No, im okay. its working now. but only if I slam the E-brake release real hard.
Old 06-12-2011, 11:05 AM
surfintazz surfintazz is offline
Vehicle: 2007 Dodge Ram 1500 Mega 5.7
surfintazz is on a distinguished road
I have the EXACT same problem... will try the e brake just to see if it's conicidence or not... when I finally find the problem I'll let you know. This is driving me nuts!!!
Old 06-12-2011, 11:11 AM
tried the e brake... it worked!! For a minute!! Then it stopped again. ARRRRRG!
Old 06-17-2011, 09:36 PM
chris0001's Avatar
chris0001 chris0001 is offline
Trim Level: SLT QuadCab 4x4
Color: SILVER
chris0001 is on a distinguished road
I was having a similar problem, found that my conector to the resistor was loose. Made sure there was a good conection and no more issues so far.... Thanks to topics like this, it gives you other places to look ,(instead of looking for your wallet at the garage...LOL).
[/SIGPIC]
