Old 10-17-2010, 10:55 AM
Leadchunker's Avatar
Leadchunker Leadchunker is offline
Vehicle: 1996 Dodge Ram 1500 4x4,
Color: Green
Rep:57
Leadchunker will become famous soon enough
Default Lift Kit Recommendation
I just bought a 96 Ram 1500 extended cab 4x4 short bed. It sits up nice however the springs seem to be very weak when loaded and the shocks are worn out. I am looking to change the springs and shocks and lift the truck about 4 inches for some larger tires. Any recommendations would be appreciated.
Chuck
Lawrenceville, GA.
Old 10-17-2010, 12:00 PM
Rep:1909
Skyjacker and Superlift make good stuff. How much larger do you want to go with the tires?
Old 10-17-2010, 01:24 PM
I agree with Randy ^^^^ on those and also check out Rough Country.
One of the things to remember is to get a complete kit otherwise you will be chasing suspension geometry problems and maybe pinion angle issues depending on how high you go.
Old 10-17-2010, 03:02 PM
Color: Green
Rep:57
I definitely want to change the leaf's on the rear, some of the kits have an add a leaf. I am looking at staying with the 16 inch rims, may get some different ones and a 305/70/R16 tire. Not sure how the dimensions equate to 15 inch, I have only had 15 inch rims in the past. I also have an '84 Bronco II that I am rebuilding, it has 15 inch rims.
Chuck
Lawrenceville, GA.
Old 10-17-2010, 04:31 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
4" lifts and 6" lifts are very close in price so I would go with a 6" lift. I had a 6" fabtech on my z71 and it treated me pretty good.
Dillon-aka, The Little Kid
Old 10-17-2010, 08:52 PM
Color: Green
Rep:57
Thanks for the advice, I will do some research on the Fabtech. I am trying to get my wife to let me put a lift on her WJ jeep. She isn't very interested
Chuck
Lawrenceville, GA.
Old 10-17-2010, 09:55 PM
ERNIETWANG ERNIETWANG is offline
Vehicle: 2001 RAM 1500 4X4 5.9L Z
Color: WHITE
ERNIETWANG is on a distinguished road
Hey leadchunker I,m down here in columbus ga,I pick up my truck tomorrow (2001 1500 ram 4x4 5.9l,) I had a five inch rough country suspension lift and some 35 12.5 17 mickey t's and mikey t's classic bead lock put on. Never had a truck with a lift will let you know how it is.
Old 10-18-2010, 12:44 AM
Coffey68's Avatar
Coffey68 Coffey68 is offline
Vehicle: 1999 Dodge Ram 1500 SLT
Trim Level: Sport 4x4 Quad Cab
Rep:29
Coffey68 is on a distinguished road
if you want a 4 inch that would look good but the 2nd generation dodges that are 4x4 already sit up pretty high. i put a 3" rough country suspension lift on my 99 sport 4x4 and it looks pretty big and i have some 295/75/16 BFGs on it right now and i could prolly go a little bigger on the tire size. and the 3" lift isnt to expensive you can get it for about $500 heres the link http://www.roughcountry.com/dodge_4wd_94-01_3.html
Old 10-18-2010, 12:29 PM
tomcatg tomcatg is offline
Vehicle: 1998 Dodge Ram 4x4 Sport
tomcatg is on a distinguished road
I agree they sit pretty high stock. I have 285x75x16's BFG MT on 16x8 Centerline Hellcats on mine with room to spare.
Old 10-19-2010, 11:17 AM
Okiespaniels's Avatar
Trim Level: Fleet
Rep:47
Fabtech "had" been having some financial issues. If you want a similar kit with springs check out BDS.
Both the Fabtech and BDS kits use a "psuedo long arm kit". IMO they ride much better than Rough country or similar systems that use the stock four link mount points. This is due to the high angle of the short arms. FTR I run Rough Country components with off road springs and in certain instances the ride can be pretty choppy.
The downside to BDS and others is that the truck will be permenently(sp) modified and welding will be required.
I am not a fan of Superlift...great lift for looks, but horrible off road. They simply converted a four link into a Ford link.
