Old 10-27-2010, 02:06 AM
FloridaCracker352's Avatar
FloridaCracker352 FloridaCracker352 is offline
Vehicle: ram 1500 extcab 4x4 1998 dodge
Trim Level: larmine slt
FloridaCracker352 is on a distinguished road
Send a message via AIM to FloridaCracker352
Post idle and tanny
hey everyone, i have a 1998 ram 1500 with the 5.9l 4x4 and when im stopped the idle some times is jumpy and the truck sounds like there's a lopy cam in it and the truck shakes not as if it would stall but more than normal. if anyone has an answer or a solution i would appreciate if you could let me know.
Also the tanny shifts pretty hard when driving normal or if im on the gas and accelerating quickly, im hoping it is not anything major. but the truck does have 197,000 miles on it and i want to keep it mechanically sound, so i can get another 100,000 miles out of her. i bought the truck with 190,000 miles so i have no record of what has been done to it except that the rear end was replace at some time as well as the fuel sending unit im guess that was only the fuel pump.
Once again thanks for any info,
FloridaCracker352
Old 10-27-2010, 09:02 AM
Rep:1845
I'd start with checking the plugs, wires, cap and rotor. Then move on to cleaning out the throttle body and IAC motor and passages. Check the trans fluid level and condition and flush it if needed.
Old 10-27-2010, 02:35 PM
Thanks ram tech i will be checking everything out this weekend.
2nd gen, idle, transmission
