Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Interior Cleaning and Maintenance!
Interior Cleaning and Maintenance! Keeping the inside clean!
Old 10-27-2010, 05:30 AM
rbu1 rbu1 is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: Crew Cab
rbu1 is on a distinguished road
Default Chrome Bug Shield
Has anyone installed part number 82211336AC? Its the chrome bug shield. I want to make sure I did it correctly. It comes with these plastic clips that go in the holes in the hood...Then you put the bug deflector over them and screw it in using 4 small black screws and washers. It seemed real easy to install. My only concern was it seemed that if I over tightened the small black screws they would just strip and keep turning without getting tight. Is this the way they install? Just snug not over tightened.....
Thanks for the help.
Old 10-27-2010, 01:18 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
If you look at the pieces that go in the hood, you will see they have a rectangle part on the side that faces the deflector. Those line up with the slots in the deflector.
As for over tightening, its hard to do because you'd strip the head of the screw first.
I suggest going to the hardware store and buy some foam weather stripping with an adhesive back. Put the adhesive side on the hood, then mount the deflector. This will help prevent wearing of your pain by the deflector. Wind going over the deflector will cause it to flex and wear your paint. Its not because the design is bad, its just physics.
Brian:
Old 10-27-2010, 02:24 PM
It seemed like the screw would just keep turning in the plastic piece and it would never get tight. I was afraid that if I just kept turning the screw it would strip out the plastic.
Old 10-27-2010, 02:25 PM
Color: RootBeer
Rep:1287
If you don't have the rectangle lined up with the slot on the deflector, what's actually happening is the piece is spinning in the hole on the hood.
Brian:
Old 10-27-2010, 04:30 PM
Well I took it back off to double check. The rectangles are in the slot on the deflector and the screw just turns. I even tried a screw in the plastic clip out of the hood and the screw only goes in so far then it will just spin. I put it back on just snuging the screws. It is tight and does not move.
Old 10-27-2010, 05:32 PM
Chubby Bruiser Chubby Bruiser is offline
Vehicle: 2010 Quad Cab
Color: Blue
Rep:84
Chubby Bruiser will become famous soon enough
Mine does the same thing. Not a very good design in my opinion. I check them every time I wash and dry. About once or twice a week.
Westin Nerf Bars, Mopar Chrome Bug Deflector, Mopar Mud Flaps, Mopar Slush Mats, Chubby Antenna, K&N Drop in Air Filter, Bosch Wiper Blades, Weathertech Vent Visors, Mopar Trailer Brake Controller, Reese Tow Package with Anti Sway Bars, B Pillar Black Tape Removed, Mopar Chrome Gas Door, Mods to come - 14 inch Mufflex, CAI, Headers, Michelin Tires, Chrome Bed Rails.
Old 10-27-2010, 05:57 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
^^^^ What he said ^^^^ I found the same problem, one of the screws just seems to turn and not tighten up however the other three are good and it seems to be on tight so I will just keep an eye on it.
Old 10-27-2010, 06:01 PM
I agree. Bad design. I guess I could get a slightly larger screw and washer. They are snug and feel tight when I pull on the deflector. Did you put anything under it to help prevent scratching? I did not.....
Old 10-27-2010, 09:01 PM
Color: Blue
Rep:84
No I have not. But I am going to take it off at my first Winter detail and see if it has done any damage and go from there. Will take the mud flaps off also to
see if they have scratched the paint also.
Old 10-27-2010, 09:11 PM
Thanks for the feedback. Gents
