Old 10-27-2010, 02:26 PM
mfrickman mfrickman is offline
Vehicle: 2006 Dodge Ram 1500
Color: Inferno Red
mfrickman is on a distinguished road
Default Any experience with Radiator/Coolant system pour-in leak sealer?
I have a 1997 Ford Escort that my little gas getter, and it has a minor coolant leak. I've looked at the local car parts stores and found a couple different products. There are ones you have to drain the whole cooling system and there's some that are just pour in. Should I find the exact source of the leak also or should I just pour and go haha. Thanks in advance.
2006 Ram 1500 - Leveling Kit, Spray in Bedliner, Volant CAI, and 3" SI/SO Flow Super 44 Exhaust.
Old 10-27-2010, 02:29 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
I'd find the leak. If its on the radiator itself, pull it out and take it to a radiator shop.
Those leak sealers can get expensive when they block up the coolant passages in the motor.
Brian:
Old 10-27-2010, 02:37 PM
Color: Inferno Red
That's what I was worried about Thanks!
Old 10-27-2010, 02:46 PM
FloridaCracker352's Avatar
FloridaCracker352 FloridaCracker352 is offline
Vehicle: ram 1500 extcab 4x4 1998 dodge
Trim Level: larmine slt
FloridaCracker352 is on a distinguished road
Send a message via AIM to FloridaCracker352
i would definiately try to locate the source of the leak other wise the problem could get worse
Old 10-27-2010, 02:56 PM
RamTech RamTech is online now
Rep:1877
Sealers = bad idea.
Old 10-27-2010, 09:47 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
They don't even help out in a pinch. If the leak is small, you can usually nurse it home. If the leak is too big, it won't help anyways.
Old 10-27-2010, 09:52 PM
xlstreetglide xlstreetglide is offline
Trim Level: SLE
Color: Grey
xlstreetglide is on a distinguished road
Those products are worthless. I tried on a radiator/heater core leak with no results. Find the leak dont waste your money!
