Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8
Dodge Ram Decals
Old 10-27-2010, 03:20 PM
Joe Daddy Joe Daddy is offline
Vehicle: 1995 Ram 1500 4wd ext 5.2
Joe Daddy is on a distinguished road
Default New to gas rams, perf, mpg, diag.
Just bought a very high mile (265k) SLT 1500 4wd ext 5.2. The DT is solid and doing tune up now. Perf mods next.
What do you sugset. For cheap or free mods?
Also I've got a whistle that sounds like vac leak and truck idles badly?????
Old 10-27-2010, 03:31 PM
Welcome to the forum. With any internal combustion engine, a cold air intake and freer flowing exhaust will work wonders.
For the computer controlled vehicles, the addition of a programmer or having a performance tune put on your PCM makes a big difference.
Sounds to me like you have a vacuum leak. It's either a cracked or loose hose; or it might be an intake manifold gasket leak or a leak at the base of the throttle body. Check those areas and makes sure your TB is on tight for a start.
Old 10-27-2010, 03:58 PM
Thanks, I should have noted that I've built many chevy engines (mostly race) and can do head porting custom cam profiles and do custom exhaust. I meant what tricks can I do that are excusive to the 5.2 mag? I'm already making a short list.
Headers
Porting TB
Porting a spacer
Fabbing a Ramair CAI
And looking into tuners or chips.
What I don't have is tech knowledge of the EFI and controls, like the AIS???
Thanks again!
Old 10-27-2010, 04:58 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Since you've worked on many engines you probably know this, but I'll say it anyway, a can of WD40 or carb cleaner is your best friend for finding vacuum leaks.
Brian:
Old 10-27-2010, 05:20 PM
Touche.
Are these intakes prone to leaking?
Old 10-27-2010, 05:57 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
Yep, it's very common, atleast among the forum members.
