Old 10-28-2010, 12:28 AM
cadco cadco is offline
Vehicle: 2003 ram 2500
cadco is on a distinguished road
Default No left hand signal light on trailer
2003 ram 2500 with factory trailer wiring
I have no left signal at either of the trailer plugs (4 pin or RV)
harness is good at back, no corrosion, good ground, no power to LH signal on trailer
I understand there are relays below the fuse box on a board.
are they serviceable?
What is the part name/number of the board?
Old 10-28-2010, 10:03 AM
Rep:1877
This may aid in your diagnosis. Start by checking the fuse and then move onto the realy coil ground.
Old 10-30-2010, 10:14 AM
Randy
Thanks for the diagram I will check it out this morning
Best regards
Old 10-30-2010, 07:55 PM
crram1500's Avatar
crram1500 crram1500 is offline
Vehicle: 2006 ram 1500
Color: Grey
Rep:32
crram1500 is on a distinguished road
are you sure the problem is on the truck and not on the trailer itself??
Old 11-02-2010, 12:48 AM
Yes The trialer checks out, it is in the truck.
Thanks.
Old 11-02-2010, 12:55 AM
Randy is the IPM below the fuse box or is it some place else?
Old 11-02-2010, 03:22 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
The IPM is the 'Fuse Box'. Fuses and relays on top.....electronics below.
brad
Interested in one of my mods?
Old 11-04-2010, 12:35 AM
Brad thanks for the clarification.
It does not appear that this truck has the trailer tow relays.
Is this possible?
Or am I missing something.
Old 02-06-2011, 12:05 AM
arsonhntr's Avatar
arsonhntr arsonhntr is offline
Vehicle: 2004 1500 Ram SLT
Color: RED
Rep:53
arsonhntr will become famous soon enough
Ive got the same problem with mine. What were ya able to find out?
Old 02-06-2011, 10:18 PM
bmucci bmucci is offline
Vehicle: 2003 dodge ram 3500
bmucci is on a distinguished road
had the same issue with mine except it was the right turn.i chased it all the way to the fuse box(isp) and could not see any problems or broken wires in the plugs.thought it was the module on the side of the fuse box(side closest to the drivers fender) so i replaced it and still didnt work.not sure if thats the bcm,maybe someone will know.anyways i went with a powered towing module that is mounted under my box and feed from 12v directly from the battery.havent had any issues yet with it. i pulled all the fuses for the trailer circuits aswell.when i spoke to the one electrical tech he told me that the trailer wiring systems in these trucks where borderline sufficient if you have a trailer with mutiple lights because of the amperage draw.hope this helps.let me know if you need any other info.
