Old 10-28-2010, 06:32 PM
BiggBerger BiggBerger is offline
Rep:43
BiggBerger is on a distinguished road
Default Driver Headlight not working
I tried to install my hids tonight, put everything in the driver side and tried it to see if it work and it did. After that I closed everything up and turned the lights on again just to make sure and the hid didnt light up so i took everything apart to check my connections again and still nothing. I tried my halogen to see if it worked and nothing. So my driver side low beam and high beam dont work anymore but the passenger side is fine. I need headlights in the morning. I need help asap. I have a 2010 with quad lights.
Old 11-02-2010, 05:13 PM
Rep:43
Ok so I took the truck to the dealer and they said my TIPM shorted out. So my question is would the HID kit have caused this? I really want to run HIDs but not if its going to cause this things to keep shorting out.
Old 11-02-2010, 05:57 PM
Rep:1885
Most likely. Consider yourself lucky if they're replacing it under warranty.
Old 11-02-2010, 07:27 PM
Rep:43
Thanks Ramtech. I removed everything that had to do with my HIDs so there was no sign of me messing with my lights or they probably wouldnt have fixed it.
