Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Place your Ad Here!
Old 10-28-2010, 08:31 PM
sgreen3's Avatar
sgreen3 sgreen3 is offline
Rep:24
sgreen3 is on a distinguished road
Default Heat ?
The truck in my sig for some reason is not blowing heat when switched to heat. I noticed the temp gauge rising an falling on the way home driving today. It will be in the middle an then go up an then fall back to the middle. Also noticed that air will start blowing out of the vents for no reason for a few seconds then it will stop when the switch is in the off position. Also it will blow out good an hot for like 5 seconds then turn to cold Any ideas? Thanks
1997 R2500 4x4 5-speed 5.9L
Old 10-28-2010, 11:16 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Lot of things. First that comes to mind is when was the last time the entire cooling system including heater core were flushed and back-flushed? Second when was the thermostat changed?
As for the blower coming on by itself, that's an electrical problem. Switch sounds goofy to me. But could be other issues.
Brian:
Old 10-29-2010, 09:19 AM
Resident Technician
Rep:1915
The heat coming and going sounds like a low coolant level. Start there. As for the blower motor, you may have a bad switch. Does it work correctly on other speeds?
Old 10-29-2010, 05:35 PM
sgreen3's Avatar
Rep:24
well i flushed the system today an installed a new t-stat. deffinatly needed done, it was like mud in there. I got the heat wrkin a lil bit now but still dont seem to be as warm as it should. Could you explain the back flush a lil more? Im pretty sure i didnt do that lol. an it seems to not be builing pressure? Thanks for ne an all help!
Old 10-29-2010, 05:55 PM
Color: RootBeer
Rep:1287
Hate to say it but I hope you didn't put all fresh new coolant in yet.
Here's how I would do it.
1. Drain the radiator.
2. Disconnect top and bottom hoses from the radiator.
3. Stuff the hose in the top port of the radiator and pump water through until it comes out nice and clear at the bottom.
4. Leave the radiator disconnected.
5. Disconnect both heater hoses.
6. Using low pressure at least until you get a nice clear stream flush the radiator using the top hose or port/connection.
7. Repeat the process with the bottom heater hose.
Once you have nice clear water coming through the heater you can increase water pressure but don't get carried away. Last thing you want is to blow out the heater core.
Button it all back up. Put WATER in the radiator. Run the truck till the temp gauge reads normal, you want the t-stat to open up. Turn on the heater to full hot. You should now have nice hot heat.
Once that's all done, shut down the truck and let it cool down. Drain all that water out which should be pretty clear.
Close up the drain and put in nice fresh coolant.
I agree with Ramtech, your blower switch is likely shot. You'll need to attend to it before you can do what I've written above.
Brian:
Old 10-29-2010, 09:28 PM
sgreen3's Avatar
Rep:24
Ok thanks for the help. I did notice a wile ago when i went to town that you can here water gurgle from the heater box when you first start to excelarate. it will do this a few times an then it will stop untill you shut it of an come back to go somewere else again an it will do it again? Any ideas on why its not building ne pressure? I did put a new rad cap on? Thanks for the help greatly appreciated!
Old 10-29-2010, 10:05 PM
Whenever you service the cooling system it is good practice to replace the radiator cap also . They don't last forever and their not real expensive .
Old 10-30-2010, 08:01 AM
sgreen3's Avatar
Rep:24
Yea i put a new one on
Old 10-30-2010, 07:06 PM
sgreen3's Avatar
Rep:24
Well I back flushed an everything, seems to have pretty good heat now. But for some reason still not building any pressure in the system. Kinda wired but its not overheating
