Old 10-29-2010, 07:49 AM
Kens04's Avatar
Kens04 Kens04 is offline
Vehicle: 2004 Ram QC 4x4 HEMI
Trim Level: SLT OFF ROAD
Rep:48
Kens04 is on a distinguished road
Default Loss of power at highway speeds
A few weeks back I thought I felt something wierd as if I took my foot off the gas as fast as I could. Almost like when your driving a stick, downshift and the vehicle kind of surges forward a little. At the time I thought maybe it was something in the road I just didnt notice.
So on my way to work this morning the same thing happens, but this time it was twice in a row and a little more noticable this time.
I know there was issues with stalling due to a clogged EGR valve but I replaced mine maybe 4 months ago and all has been fine since.
I had an 86 toyota truck many years back and when the fuel filter started to go it was a similar feeling, replaced and all was good. I know the fuel filter in my truck now is in the tank and is supposed to last.
ANy help? Comment, questions, concerns? Thanks
Old 10-29-2010, 08:24 AM
Interesting problem. Any codes?
You say it feels like a surge when you lift off the gas? What gear are you in when this happens.
Old 10-29-2010, 08:53 AM
Kens04's Avatar
Rep:48
No Im not moving my foot off the gas, but feels like I am taking it completely off. No codes.
Its got to be in fifth gear, I was going about 60mph and a slight downhill grade, but not enough for the tranny to downshift for any reason.
Old 10-29-2010, 09:43 AM
Kens04's Avatar
Rep:48
So I just read (googled my problem) that someone else had a very similar issue only more frequent, and no codes. They had cat conv., plugs wires, cap and rotor replaced, new fuel pump, and found out it was a bad O2 sensor.
Granted this was on an 01 and mines an 04. Hypothetically speaking if it was the same issue, how do you diagnose soemthing like that without a CEL? O2 sensors seem to always be setting the CEL on.
Old 11-04-2010, 03:46 PM
oklahemi oklahemi is offline
Vehicle: 2004 Dodge Ram
Trim Level: Laramie Sport
Rep:30
oklahemi is on a distinguished road
my trck acted weird like it was stuck in a lower gear and wouldnt upshift. it turned out to be the throttle position sensor. try resetting your pcm or calibrating the sensor to see if it helps
Old 11-04-2010, 04:00 PM
Rep:1909
The way to diagnose a bad O2 sensor that isn't setting a code is with a lab scope so you can see the waveform and dtermine if there are any glitches, dropouts or if the sensor is just lazy.
